When I try to print from model or paper space, either to a printer or to a pdf, nothing shows up from my drawing except the xref file. Is there some setting in my drawing file that needs to be adjusted?
P.S. I have checked to make sure that there are no 'no plot' layers turned on. Also, it appears to be something to do with the xref file because when I print something beyond the limits of the xclip, it shows up okay but if I overlap the xclip with my print area it disappears again.
Have you looked in all three seprate places for the Layer Manager? If i remember correctly there is one for Model Space, Paper Space, and your Viewport.
It could be that your viewport layers are not turned on to plot.
