Is it possible to write a lisp routine that will take a single line text and adjust it up or down digets? When I draft a line and tag is 10-0 I would like to be able to build a routine to go through the drawing click on the object and have it adjust down 2, making it 9-10. Anyone have some suggestions or idea if it is even possible?
First, please ask a moderator to move your thread in the appropriate section. You issue will get more support there.
Second, what type of entity is that tag? You are talking about a text or a dimension?
Regards,
Mircea
Your routine will be like:
;select entity to edit (ENTSEL)
;get the associated list of the entity (ENTGET)
;get the label content (ASSOC)
;convert that value to a double taking care of format (DISTOF)
;perform the math
;convert back the value to string taking care of format (RTOS)
;modify the associated list of the entity (SUBST)
;update the entity (ENTMOD)
Please try to follow the above scheme and ask where you have issues. Good luck!
Regards,
Mircea
Thank you for the tip, Mircea. The thread is moved.
I guess you mean reversing string.
(defun c:TesT (/ ss sset lst e)
 ;; Tharwat 04. 08. 2011
 (prompt "\n Select Texts to reverse >> ...")
 (if (setq ss (ssget "_:L" '((0 . "TEXT,MTEXT"))))
   (while
     (setq sset (ssname ss 0))
      (setq lst (vl-string->list (cdr (assoc 1 (setq e (entget sset))))))
      (entmod (subst (cons 1 (vl-list->string (reverse lst)))(assoc 1 e)  e ))
      (ssdel sset ss)
Tharwat
Sorry @Tharwat, but seems to me that the OP isn’t looking for a reversing string routine.
Regards,
Mircea
......When I draft a line and tag is 10-0 I would like to be able to build a routine to go through the drawing click on the object and have it adjust down 2, making it 9-10.
Are you saying "adjust it down" is 10-0 less 2 is 9-10. so 10-1 will be 9-11?, and if "up" 9-11 will be 10-1?
10-2 to 10-0? :unsure:
@pBe: The OP is talking about imperial values: 10'-0" (10 feet, 11 inches) minus 2" (2 inches) will be 9'-10" (9 feet, 10 inches).
(rtos (- (distof "10'0\"" 4) (distof "2\"" 4)) 4)
(Or, maybe, I didn't understood your question?)
Regards,
Mircea
Regards,
Mircea
I guess you're right msasu.. thought it would be more complex than that like
sheet numbering, i.e. sheet number 9 of 10 sheets or 13 of 19... , so the first and second digits would vary greatly,
it would have been a fun code to write :)
EDIT:
Odd as it is, give this a try
(defun c:Addless ( / DoTheMath strs str j intval)
(defun AddSub (ent sym  num / strs g DoTheMath ft)
     (setq strs (vla-get-textstring ent))
     (setq g (read (strcat "(" (vl-string-subst " " "-" strs) ")")))
     (setq DoTheMath (/
                ((eval (read sym))
                      (+ (* (car g) 12.0)
                         (cadr g))
                      num) 12))(vla-put-textstring ent
      (strcat (itoa (setq ft (fix DoTheMath))) "-"
              (rtos (* (- DoTheMath ft) 12) 2 0)))
     (cond ((and
 (setq strs (ssget ":L" '((0 . "*TEXT"))))
                     (initget 7)
                     (setq IntVal (getint "\nEnter Value to Add\Subtact: "))
       (princ "\nPress [+/-] Any key to Exit")
 (while (member (setq j (grread nil 10)) '((2 45)(2 43)))
 (if (member j '((2 45) (2 43)))
     (repeat (setq i (sslength strs))
                          (setq str (vlax-ename->vla-object (ssname strs (setq i (1- i)))))
                     (Addsub str (chr (cadr j)) IntVal))
Notice how mess up the way i do the math? :D
well i guess you get the general idea :)
Edited by pBe
