Hello everyone! I've been searching for days off and on trying to find a solution to a problem I have. I have seen several people ask a question very similar to this, but have found no answers.
I have hundreds of polylines in my drawings, which represent steel reinforcement... I would like to use data extraction to take the lengths of these polylines, do some simple arithmetic to them and export this information into a table, or excel spreadsheet so that I can show the cut length, elongation, etc... The problem I'm having is that I have no way to identify which polylines are which. I need a way to name a polyline (i.e Tendon_1, Tendon_2, etc.. ) so that the length of the polylines are useful to me. The lengths are generally many different values. Looking at the data extraction set for a polyline, there are several categories which I could use, such as comments, subject, title... although I don't know how to assign this attribute to a specific polyline.
So I'm guessing I need a lisp routine to tag polylines with a marker of some kind??? Anyone have any ideas?
Thank you so much.
Try the following 2 lisps I made up
Feel free to change both to your suit
;; AXD.lsp
;; set xdata
(vl-load-com)
(defun C:AXD (/ acapp adoc appname counter obj ss xtype xvalue)
 (setq acapp    (vlax-get-acad-object)
             adoc     (vla-get-activedocument acapp)
 ;; define application name
 (setq appname "STEEL_ENFORCE")
 ;; register application, if this registered earlier,
 ;; just ignore it
 (vl-catch-all-apply
   (function (lambda()
	(regapp appname)))
 (alert (strcat "Select steel enforcement,\n
then enter data for them,\n
then repeat the same for next one"))
 (setq counter 1)
 (while ; loop
   (setq ss (ssget "_+.:S:E" (list (cons 0 "*POLYLINE");|(cons 8 "M-STEEL-DETAIL")|));<==change layer name if you need it
       (setq obj (vlax-ename->vla-object (ssname ss 0))
             xtype    (list 1001;|appname|;
		     1000;|Tendon#|;
		     1041;|length|;
		     1041;|elongation|;
		     1040;|diameter|;
		     1000;|subject|;
		     1000;|comments|;
		     1000;|title|;
            (setq xvalue   (list appname
                  (strcat "Tendon_" (itoa counter))
	   (vlax-curve-getdistatparam obj (vlax-curve-getendparam obj))
	   (getreal (strcat "\nEnter elongation for Tendon#"  (itoa counter) ": "))
	   (getreal "\nEnter diameter: ")
                  (getstring T "\nEnter subject description (less than 256 characters!): ")
	   (getstring T "\nEnter comments (less than 256 characters!) : ")
	   (getstring T "\nEnter title : ")
       (vlax-invoke
         obj
         'SetXdata
         xType
         xvalue
(setq counter (1+ counter))
(setq xvalue nil)
(princ "\nType AXD to add xdata")
;; XDT.lsp
;; read xdata and write it in .CSV file (comma separated)
(vl-load-com)
(defun C:XDT  (/ appname data en fdesc fn obj ss xdv)
 (setq fn (strcat (getvar "dwgprefix") (vl-filename-base (getvar "dwgname")) ".csv"))
(if (not (findfile fn))
(setq fdesc (open fn "w"))
(setq fdesc (open fn "a"))
 (setvar "cmdecho" 0)
 (write-line "Name,Length,Elongation,Diameter,Subject,Description,Comments,Title" fdesc)
 (setq ss (ssget "_X" (list (list -3 (list appname)))))
 (while (setq en (ssname ss 0))
   (setq obj (vlax-ename->vla-object (ssname ss 0)))
   (vla-getXdata
     obj
     appname
     'xtp
     'xdv
   (setq data
   (cdr (mapcar 'vlax-variant-value
	   (vlax-safearray->list xdv)
   (ssdel en ss)
   (write-line (strcat (car data) ","
		(rtos (cadr data) 2 2) ","
		(rtos (caddr data) 2 2) ","
		(rtos (cadddr data) 2 2) ","
		(nth 4 data) ","
		(nth 5 data) ","
		(nth 6 data))
		fdesc)
 (close fdesc)
 (setvar "cmdecho" 1)
(princ "\nType XDT to write xdata to file")
~'J'~
Thank you very much fixo. I have never used Xdata before, and it will be a good thing for me to learn.
Thank you again.
