Goodmorning all,
I want to save all tile in a DCL dialog when it unload (store in a list), and when it reload, Dialog can restore all value of controls from last value, how can i do it??
Yesterday i've write
hello:dialog {
label="Test";
        : edit_box {
                   label = "test";
                   key = "kPath";
                  [color=red] value = "default" ;[/color]
When the first dialog load, it will show "default"
Now i goto change it to "new"
And i need in the next time load, it show "new", not "default" any more
I find a link below, but i don't know what/ and how i can use
http://www.cadtutor.net/forum/showthread.php?54791-DCL-Image-slide-by-list-box-amp-edit-box-help!&
Thanks all o:)
Thank you,OK, i understand assign value to one control now, but i want do it with all of control in dialog (have many other control ) or i have to do with each of them ?
I started learn DCL yesterday, so ....
for multiple action_tile/set_tile it would be easier to name your variable the same as the key name.
which means gloabal variables
 (setq KeyValueList  (list "Key1" "key2" "key3"))
Set_tile:
 (foreach Key KeyValueList
      (set_tile key (eval (read key))))
Action_tile:
      (action_tile Key
             (vl-prin1-to-string
 (quote
  (setq key $key)))
or you could add an additional character at the end of the keyname
       (set_tile key  (eval  (read (strcat key "_X")))))
      (action_tile Key
             (vl-prin1-to-string
 (quote
  (set (setq tmp (read (strcat
         $key "_X"))) $key)))
Which gives you variable "key1_x" for key "Key1"
Hope this helps
Thanks for ur reply, i'll try it ^^
You might want to write the dialog input to a file then retrieve it when the dialog opens.
This will give you more options later as you write bigger more complicated projects.
Once you get comfortable with it you can have programs that allows the user to save different settings and then load those settings.
