Hello.
I have a big problem in AutoCAD files.
Lines are drawn together.
So that the file is busy.
I am looking for a command that extra line below the main line is being erased
As the top line is there to stay, and underline and additional lines to be deleted.
Do you actually want to delete the overlapping geometry on the lower plane, or just have it hidden? I think if you're going to work in 3D, you may want to use objects with 3D properties.
hi. i want clear under line.beacuse when exist underline in each height , autocad snap is going to be stupid!
For example, when the plan by a line connected to my second point.
When I see in isometric view
Or when I want Boundry ,error occurs because the problem is the underlying cause.
