PDF to DWG converters. How good are they? I currently convert with CorelDRAW.
I have been using CorelDRAW to PDF's with vector information to DWG's. It is not something I do often so it was fine. I got a few more PDF drawings and decided to try the converters available. These are the trial versions, but the output seems to be worse than what I get with Corel. Is there any one in particular that gives excellent conversions. I can see spending $200 plus to get what I already get wit Corel.
I've had good luck with dopdf - it's a free one.
The only time it has given me problems is when I had any kind of bit map scan as part of the sheet. If it was too much bit map data it would take a really long time or freeze up.
Luckily AutoCAD has a converter built in on the newer versions which has worked well for me even with bit map data.
Pdf to cad?:rtfm:?:rtfm:
Ooops, misread as dwg to pdf.
Not sure how much I like those new emoticons yet ;)
I use GSVIEW with PStoEdit and convert to DXF. So far as long as the PDF was a vector the results are pretty good. Other than that I just insert and trace over.
i agree with SLW210 i jsut insert and trace over making sure it is to scale, not worth the hassle of converting when for example if there is a dashed line you get a little line for every dash, you still have to trace over it anyway so why bother converting just insert it works pretty good i do it all the time and am only out by maybe 5-10mm when we get the actual DWG files from clients,etc.
On occasion, I use pdf2cad. Usually end up redrawing quite a bit but, gets you moving.
If the pdf was a scan, you get a blank dxf and a tiff image. You would have to trace (after scaling) the image.
Then, delete the image from the drawing; save as a dwg file.
Results are usually, ugh.
I've used this one on vector PDF's and was satisfied with the results. This one doesn't have a time limit on the trial, rather a limit on how many drawings can be converted (30), which works well if you don't need to convert PDF's very often. http://anydwg.com/
