walls go bye bye
I am in the middle of a model and something has happend where my walls are no longer refrenced.
Style not found in location drawing. Using Standard style.
I am pretty sure that I haveset the support file to the right place any ideas?
How are you trying to reference a wall? I'm not seeing anything in AutoCAD for referencing a wall. :?
In options there is file referencing. The tool palette reference goes to the imperial tool catalog.
The poster is using AutoCAD Architecture, not vanilla.
To the O.P., what Display Representation are you currently in? Are the walls visible in Plan View but not in a rotated Model View? Also see what your cut plane is set at. Do you have any doors or windows attached to the wall, and if so can you see them?
I am still in wireframe, I can see them in plan view and yes they disapear when rotated. The cut plane is stand 3-6". Doors and windows disappear as well when roatated. In properties is calls the AEC wall instead of the stud-X wall style. I get the error "Style not found in location drawing. Using Standard style.". Even when I go to styles manager, Copy walls from another drawing into the current I get the same error. I have went into the files reference and linked every location of a wall styles and still nothing. I am at a lose. It seems to me like a link or file has be broken.
Thanks for the help.
Yeah it seems something went haywire. I still wonder if the Wall Style copied over correctly? Does the same Wall Style appear in other drawings where it was been used?
Yeah, all drawings are not crapped on. I am missing some link and do not have any idea how the link broke. It is not liek I have been deleting or move files. I will keep looking for a few more mins then I guess a fresh install will solve that issue.:ouch:
thanks for looking into it though!
Relocated this thread to the Architecture & ADT forum.
