Proctor Posted August 10, 2011 Posted August 10, 2011 Hello: I'd like to set my dimension style so that it will remain the same all the time. Here's what I'm doing so far: Click Format menu--> Dimension style-->pick dimension that will be changed. Choose Modify--> click text--> then insert text height. Click to set current. When I do this, it works till I close my drawing; however, when I re-open Cad, I have to do this all over again. How can I retain my settings? Thanks for your help, Proctor ps...I'm using Autocad mechanical 09 Quote
JD Mather Posted August 10, 2011 Posted August 10, 2011 Are you using a custom template or are you using the built-in default template? Are you saying it is changing in a particular file - or when you start a new file? Quote
Proctor Posted August 10, 2011 Author Posted August 10, 2011 Hello: I'm using the built-in default template. Proctor Quote
nestly Posted August 11, 2011 Posted August 11, 2011 Proctor, when you make changes to the Dimension Style, you're only changing it for that drawing. In order for those settings to be retained when you start a new drawing, you have to save the drawing as a template. You can also import your custom dimension styles from another drawing with Design Center (as long as the Dimstyle has a different name than those that already exist in the target drawing) Quote
ReMark Posted August 11, 2011 Posted August 11, 2011 For your consideration and building on what nestly said you might want to create a custom template with all your layers, linetypes, dimension styles, text styles, system variables, etc. and use it whenever you start a new drawing. Think of the time you'll save. You'll amaze your co-workers and your boss will think you're a genius, give you a promotion and a big raise to boot! Quote
Proctor Posted August 11, 2011 Author Posted August 11, 2011 Thank you for your suggestions. As suggested, I built a custom template to use when I start a new drawing.....and everything's working great now!! Thanks again, Proctor Quote
nestly Posted August 11, 2011 Posted August 11, 2011 Think of the time you'll save. You'll amaze your co-workers and your boss will think you're a genius, give you a promotion and a big raise to boot! Imagine how wealthy you'd be if you got a percentage of all the added productivity resulting from your help/tips. Quote
ReMark Posted August 11, 2011 Posted August 11, 2011 But I am wealthy. Look at all the people I have gotten to meet and interact with, like yourself, over the past 6 years. Priceless. Quote
