andre81 10 Posted August 10, 2011 Hi All, I'm Autolisp beginer and first problem which I would like to solve with it is how to restore layers Visibility after Layiso command. In few steps it's looks like: 1. Before use Layiso command I'have some layers that are on others are off. 2. I'm using Layiso and makes some changes on drawning. 3. After changing I want to restor layers visibility from point 1 (before Laiso command). My idea is to use LayerState functions: layerstate-save, layerstate-delete and layerstate-restore. I have problem with using LayerState functions. I could name functions for example "Iso" and "RestoreState". LayerState name could be "XX" Program structure: Step 1 - c:Iso I'm checking if "XX" exist. If "XX" exist then using layerstate-delete I'm deleting "XX". I'm creating LayerState "XX" using layerstate-save. Step 2 (command "Layiso") Step 3 I'm doing some changes in drawing. Step 4 - c:RestoreState I'm restoring "XX" using layerstate-restore. My problem is that I don't know how to use LayerState functions. Many info I've found here: http://www.cadtutor.net/forum/showthread.php?39986-LayerState-Manipulation-Info.-Coding but still don't know how to for example make Layerstate "XX" using it. (layerstate-save XX) or (layerstate-save "XX") don't work. How it should look like? Also I've tried to use only commands: (defun c:iso ()(command "-layer" "state" "save" "XX" "" "" "" "LAYISO")) (defun c:RestoreState () (command "-layer" "state" "restore" "XX" "" "")) This code don't has checking if "XX" exist but works. How to write code using LayerState functions?? Anyone can help? Sorry for my English Quote Share this post Link to post Share on other sites
alanjt 10 Posted August 10, 2011 LayUnIso? ....... Quote Share this post Link to post Share on other sites
andre81 10 Posted August 10, 2011 I forgot about this Thank you. How to use "layerstate-save" with defined function name "XX"? Quote Share this post Link to post Share on other sites
alanjt 10 Posted August 10, 2011 I forgot about this Thank you. How to use "layerstate-save" with defined function name "XX"? layerstate-restore L Functions length AutoLISP Reference Guide > AutoLISP Functions > L Functions > Expand All Collapse All layerstate-save Saves a layer state in the current drawing (layerstate-save layerstatename mask viewport) Arguments layerstatename A string specifying the name of the layer state to save. mask An integer sum designating which properties in the layer state are to be restored. 1- Restore the saved On or Off value 2- Restore the saved Frozen or Thawed value 4- Restore the saved Lock value 8- Restore the saved Plot or No Plot value 16- Restore the saved VPVSDFLT value 32- Restore the saved Color 64- Restore the saved LineType 128- Restore the saved LineWeight viewport An ename (ads_name) of the viewport whose VPLAYER setting is to be captured. If nil, the layer state will be saved without VPLAYER settings. Return Values T if the save is successful; otherwise nil Examples (layerstate-save “myLayerState“ 21 viewportId)T(layerstate-save “myLayerState“ nil nil)nil Please send us your comments about this page .................. Quote Share this post Link to post Share on other sites
