redwarve Posted August 11, 2011 Posted August 11, 2011 I have two objects in my model space, i want one object to be a sw isometric view & the other object to stay in the normal top view. Is this possible? Quote
mdbdesign Posted August 11, 2011 Posted August 11, 2011 Use paper space, unless you 3d rotate object to show in SW Quote
nestly Posted August 11, 2011 Posted August 11, 2011 You can create a 2nd Modelspace viewport using the VIEWPORTS command, if that's what you're trying to do? Quote
ReMark Posted August 11, 2011 Posted August 11, 2011 To see both views in a paper space layout would require two viewports. Quote
