ntptorres Posted August 11, 2011 Posted August 11, 2011 :DHello, I need to do an animation,what kind of software should I use.... ??? I saw an animation at portographics.com and is very good... I dont know what software they use but is good...very good.... tha animation that I want to do is about a house and wallk in his interior....!!! the animation in autocad take to much time.... so Im looking others ways to do it....! Quote
BlackBox Posted August 11, 2011 Posted August 11, 2011 If you're going to be creating an animation using AutoCAD data, files, etc. then I would suggest using 3D Studio Max. If you're wanting to create animations from your own modeling, or for media production (TV, Movies, Web, etc.) then I'd suggest you use Maya. HTH Quote
JNieman Posted August 11, 2011 Posted August 11, 2011 Autocad can do great walkthroughs. It has the Mental Ray rendering engine built in, iirc, and using the "ANIPATH" command, you can assign camera path, and camera target path, to plines/splies/lines/arcs you draw in your model. It takes a long time to render a decent animation, depending on your visual style or render preferences. Check "ANIPATH" in the help files. Draw a line where you want the camera to move (the viewer's eyes) and a line where the camera to point to (where the person is looking) - then pick a simple shaded visual style "Realistic" - and hit go. After you get the gist of it you can do more complicated things, like long 3dPline paths, and render settings, etc etc. Quote
rkent Posted August 11, 2011 Posted August 11, 2011 Here is a source for a how to manual. http://www.upfrontezine.com/aa12/ I am not affiliated with the above. Quote
rookie37 Posted August 12, 2011 Posted August 12, 2011 I'm also interested. However, I'm moving over to Mac. Does 3Ds work on mac? Also, do you know of a similar mac program? Quote
ntptorres Posted August 13, 2011 Author Posted August 13, 2011 TO UNDERSTAND THE ANIMATION THAT IM LOOKING TAKE A LOOK TO http://www.portographics.com/ Quote
Cad64 Posted August 13, 2011 Posted August 13, 2011 I'm moving over to Mac. Does 3Ds work on mac? From Autodesk: Boot CampYou can install Autodesk 3ds Max and 3ds Max Design 2012 software on a Mac® computer on a Windows® partition. The system must use Boot Camp® application program to help manage a dual OS configuration and meet the minimum system requirements. Intel®-based Mac Pro or MacBook® Pro computer¹ Mac® OS X 10.5.x or higher operating system Boot Camp V 2.0 or higher Minimum 2 GB RAM (4 GB recommended for 32-bit Windows, 8 GB or more for 64-bit Windows) Minimum 20 GB disk space for Apple OS partition, minimum 20 GB for Windows OS partition Mac Virtualization on Parallels Desktop Autodesk 3ds Max and 3ds Max Design 2012 can be used on the Mac via Parallels Desktop® for Mac software without having to boot directly into the Windows OS so it is easy to switch between platforms. The system must meet the following requirements: Intel-based Mac Pro or MacBook Pro¹ Mac OS X 10.5.x or higher Parallels Desktop 4.0 (4.0.3844 or higher)² Minimum 4 GB RAM (6 GB system memory for 32-bit Windows, 8 GB or more for 64-bit Windows recommended) Minimum 40 GB available disk space (100 GB recommended) http://download.autodesk.com/us/3dsmax/documentation/3ds_Max_FAQ.pdf Quote
Cad64 Posted August 13, 2011 Posted August 13, 2011 TO UNDERSTAND THE ANIMATION THAT IM LOOKING TAKE A LOOK TO http://www.portographics.com/ Look at the 3DWALK, 3DFLY and ANIPATH commands. Quote
JNieman Posted August 13, 2011 Posted August 13, 2011 TO UNDERSTAND THE ANIMATION THAT IM LOOKING TAKE A LOOK TO http://www.portographics.com/ That can be done, sure. That's about the limit of Autocad animation, but it can be done. Quote
duyuanxin Posted August 17, 2011 Posted August 17, 2011 Navisworks can direct open cad 3d model and can wallk in a house in his interior Quote
