Well that would answer your question then :facepalm:
You're right!
But anyway, as far I know that text styles can be changed individually if they exist. Right or wrong?
Giovanni
  • Replies 25
  • giovanni64
    10
  • Lee Mac
    7
  • irneb
    2
  • Baber62
    2
Well ... right and wrong :shock:
The Calibri is a font, which can be applied to a style. You can name the style also Calibri, though it might be called anything else as well.
Further, a MText may have internal format codes. These are independent of the style applied to the text entity.
OK, I see and the best will be to play around with it and find out what happens when I choose on or the other. However, thanks a lot!
Giovanni
  • 4 years later...
Hi Lee,
I tried your routine but it seems to work only on single line text. Have you got a routine which which adjust size (height) for multi-line text as well?
Try changing:
"TEXT"
to:
"TEXT,MTEXT"
