Nick@TE-Direct Posted October 10, 2008 Posted October 10, 2008 Hey guys- I am trying to render a Spool of wire that I created in AutoCAD 2002. My problem is when I render the spool and everything that is a circle does not come out smooth, it looks almost like an octagon. Any body know if there is a system setting I need to change to resolve this? Quote
Noahma Posted October 10, 2008 Posted October 10, 2008 Hey guys- I am trying to render a Spool of wire that I created in AutoCAD 2002. My problem is when I render the spool and everything that is a circle does not come out smooth, it looks almost like an octagon. Any body know if there is a system setting I need to change to resolve this? if they are Mass elements, try AECFACETDEV and change it to say .00001 Quote
PS_Port Posted October 10, 2008 Posted October 10, 2008 Try setting FACETRES to a higher value, 2002 default was pretty low if I remember correctly. Quote
Nick@TE-Direct Posted October 13, 2008 Author Posted October 13, 2008 Try setting FACETRES to a higher value, 2002 default was pretty low if I remember correctly. That worked perfect, thanks a lot Quote
