grasshopper Posted August 16, 2011 Posted August 16, 2011 HELP - I am using ACAD 2010, I am trying to use an XREF and everytime I try to insert it, I keep getting this error message reading *INVALID* regenerating layout, this is a first time problem for me and really could use some help trying to solve this. Much Appreciation in advance folks Quote
CyberAngel Posted August 16, 2011 Posted August 16, 2011 Are you trying to insert it in paper space? Have you already inserted an xref with the same name? Does the xref reference the current drawing as an xref, i.e. are you attempting a circular reference? Quote
roshen_aliary Posted October 5, 2012 Posted October 5, 2012 HELP - I am using ACAD 2010, I am trying to use an XREF and everytime I try to insert it, I keep getting this error message reading *INVALID* regenerating layout, this is a first time problem for me and really could use some help trying to solve this. Much Appreciation in advance folks I also encounter this today....any comments and advice why this problem occur. Thanks in advance! Quote
Tiger Posted October 5, 2012 Posted October 5, 2012 Hi Roshen, You can start by answering CyberAngels questions in post #2 -those are common errors with X-refs. Quote
roshen_aliary Posted October 5, 2012 Posted October 5, 2012 Hi Roshen, You can start by answering CyberAngels questions in post #2 -those are common errors with X-refs. Hi...I also encounter this...that's why I also seek for any help. Quote
Tiger Posted October 5, 2012 Posted October 5, 2012 Hi...I also encounter this...that's why I also seek for any help. Please answer the following questions: 1: Are you trying to insert it in paper space? 2: Have you already inserted an xref with the same name? 3: Does the xref reference the current drawing as an xref, i.e. are you attempting a circular reference? Quote
roshen_aliary Posted October 5, 2012 Posted October 5, 2012 Yup I am trying to insert it in a paper space...but when I command xr...then the dialog box for xref come out there is no xref listed. Thanks! Quote
roshen_aliary Posted October 5, 2012 Posted October 5, 2012 Please answer the following questions: 1. Yup I am trying to insert in a paper space. 2. Yup I already inserted an xref with the same name, but when you take alook the dailog box for xref no xref listed on it. 3. Nope Quote
Tiger Posted October 5, 2012 Posted October 5, 2012 Have you tried a PURGE and AUDIT before you inserted the X-ref? Quote
roshen_aliary Posted October 5, 2012 Posted October 5, 2012 Have you tried a PURGE and AUDIT before you inserted the X-ref? I already purge it but I did not try to audit it. Ok I'll try it. Thanks Tiger! Quote
roshen_aliary Posted October 5, 2012 Posted October 5, 2012 Thank you so much Tiger...it works on my drawing. Quote
Dadgad Posted October 5, 2012 Posted October 5, 2012 Did you specify the insertion point, when you were inserting it? It sounds like you may not have. Did you ZOOM > EXTENTS after inserting it? Quote
roshen_aliary Posted October 5, 2012 Posted October 5, 2012 Thank you so much Tiger...purge and audit...it works on my drawing. Quote
roshen_aliary Posted October 5, 2012 Posted October 5, 2012 Did you specify the insertion point, when you were inserting it?It sounds like you may not have. Did you ZOOM > EXTENTS after inserting it? Thanks also Dadgad... Quote
Dadgad Posted October 5, 2012 Posted October 5, 2012 You're welcome, glad Tiger got you squared away. Quote
