Display Road Studs perpendicularly
Hi,
I am trying to show road studs (cats eyes) along road markings for the entire length of a new road project. The centreline road studs are at 6m spacings and the edge of carriageway studs are at 12m spacings. At every 12m from left to right there should be 3 studs in line with eachother. I have not been able to produce this. I created a block of each of the different stud types and inserted them onto the relevant marking with the measure command, aligned to the marking and at 6m or 12m spacing. In the attached pdf you can see how a problem occurs at the curves where the studs (even though spaced right) do not line up.
Does anyone have a fix for this?
Thanks
Road Markings & Studs.PDF
Maybe try and make a block for the left and right using a base point offset from center that is the required distance from the centerline. then use the centerline for the Distance command.
