Is it possible to use ObjectARX with dev c++ instead of MS Visual C++ ? if so is there a tutorial how to configure it? thanks.
Yes I believe it is possible. You might inquire over here about tutorials....
AutoDesk Discussion Groups > AutoCAD > AutoCAD Customization > Visual Lisp, AutoLISP and General Customization.
@ Mark - The OP is asking for information about ObjectARX (C++.NET for AutoCAD), and not Visual LISP (two completely different APIs).
@ orange - According to the System Requirements listed for ARX development, you must use:
Microsoft® Visual Studio® 2008 (SP1) software for C/C++ development
Microsoft® Visual Studio® 2010 software for managed code development
HTH
I agree. I saw a thread in the forum I mentioned that seemed to indicate the OP was already doing something similar.
If your concern is using the free Dev C++ in lieu of full Visual Studio, then simply use Visual Studio 2010 Express (available for C++, C#, and VB.NET). I have all three installed on my computer. Unlike C#, and VB.NET Express IDE I *believe* Express C++ IDE fully supports the AutoCAD ARX Wizards (for templates, etc.).
I personally am starting to use C#,VB.NET, and modifying the *.*proj files' XML code to enable them to launch AutoCAD/Civil 3D at Debug, and modified acad.exe.config's XML to allow for hitting breakpoints, etc. See here.
HTH
thanks for replies. I'm sort of a (ambitious!) beginner. I've tried devc++, it complains about lack of 'atlbase.h' google suggests that Visual Studio 2010 Express has the same problem. Can Microsoft® Visual Studio® 2010 ultimate be used to make C++ or 2008 version is a must? I need it to make custom properties, like here: http://through-the-interface.typepad.com/through_the_interface/2008/11/adding-custom-p.html
Thread relocated to the .NET, ObjectARX & VBA forum. :thumbsup:
  • 1 month later...
I did some research and it seems visual studio 2005 should be used with autocad2009. can someone please tell me if visual studio 2008 would work too?
