I just made the switch from 06 to 09 and now I can't find the quick leader. I use it to point to things and create labels. Thanks.
Yes, it's still there. Type in QLEADER, then you can adjust the settings on the screen.
Same situation in A2008. The command is still there, AutoDesk just pushing multileaders more.
If you prefer Quick Leader, the command and icon is still in the CUI. Just do a search for Quick Leader and add it to a toolbar/pallet...unless you do key entry.
That's what happens when AutoDesk decides to make a change. They don't really consider the fact that there are people who actually use some of the commands they are taking off a toolbar or not incorporating into a panel. First they make you switch to command line entry then ultimately they do away with it altogether. You're only recourse is to use the "classic" setup (hope all your toolbars migrated over from your previous release) or to try your hand at customization (add a toolbar button). Why should you be forced to do that if you have no desire?
