Hi gurus. How can I drop the zero ".0" is the sum is "5.0". I need all the trailing zeros to be removed.
eq. sum = 5.0 -> 5
sum = 5.40 -> 5.4
sum = 6.4800 -> 6.48
sum = 7.514500 - 7.5145
Thanks
(defun c:test ()
(setq a (getreal))
(setq b (getreal))
(princ (strcat (rtos (+ a b) 2 1) "abc"))
  • Replies 21
  • shakuhachi
    7
  • Lee Mac
    6
  • BlackBox
    6
  • Lt Dan's legs
    2
values are not distance but volume. I'm getting value something like 10'-8".
(setvar 'dimzin
Looks an awful lot lot a measurement of length (distance) to me (ten feet-eight inches).
Anyway, you can also try vl-princ-to-string... example:
_$ (vl-load-com)
_$ (vl-princ-to-string 7.514500)
"7.5145"
_$
Edit: This would allow for you to retain your DIMZIN setting, without the need for error checking & restore.
HTH
Great info Renderman
:beer:
(vl-string-right-trim ".0" <string>)
^^ Another great option.
I thought of that one first, but for some reason (mis-)remembered that it would remove all instances of the character-set in one swoop... thought I remembered needing to use a while+trim combo once before. Guess that's what I get for not trying it for myself! :facepalm: LoL
Thanks guys it works but combination of both.
(vl-string-right-trim ".0" (vl-princ-to-string x))
Why not use rtos?I did, look on post # 1. The output I get is in distance something like 10'-8". I need to remove all trailing zeros and period if any on the total. If the output value is a whole number I want it to be an integer and if the value is a real number, I want to remove all trailing zero.
Why not use rtos?
Why not use rtos?
1+
(vl-string-right-trim "0" (rtos x))
(setq x 15.0)
"1'-3\"" value I get, needs to be 15
1+
(setq x 15.0)
Then perhaps you need to conditionally parse your value -->> into the desired format.
Perhaps this will help:
(defun FEET (s)
 ;; © RenderMan, 2011
 (substr s 1 (vl-string-search "'" s)))
Extract inches from string:
(defun INCH  (s / i)
 (substr s (setq i (+ 2 (vl-string-search "-" s))) (- (strlen s) i)))
Examples:
_$ (feet "10'-11\"")
"10"
_$ (feet "10000'-11\"")
"10000"
_$ (inch "10'-11\"")
"11"
_$ (inch "10'-1111\"")
"1111"
_$
HTH
(setq x 15.0)
(vl-string-right-trim ".0" (rtos x 2))
didn't work either.
try:
Command: (setq x 1510.0)
1510.0
Command: (vl-string-right-trim ".0" (rtos x 2))
"151"
Which format is it "1510.0" or "1'-3\""???
 (defun supp0 (str / a )
     (setq a (reverse (vl-string->list str)))
      (while (= (car a) 48)
                   (setq a (cdr a))
       (setq a (if (= (car a) 46)(cdr a) a))
(vl-list->string (reverse a))
(supp0 "5.40")
"5.4"
(supp0 (rtos 6.4800 2))
"6.48"
(supp0 "7.514500")
"7.5145"
(setq x 1510.0)
(supp0 (rtos x 2))
"1510"
didn't work either.
try:
1510.0
"151"
Oh - good catch, I overlooked that behaviour with vl-string-*-trim.
A quick fix would be:
(vl-string-right-trim "." (vl-string-right-trim "0" (rtos x 2)))
But this still assumes DIMZIN is set to something other than say, 8 (where trailing zeros are removed anyway).
So perhaps this is better:
(defun _TrimTrailingZeros ( s )
   (if (vl-string-position 46 s nil t)
       (vl-string-trim "." (vl-string-right-trim "0" s))
       s
DIMZIN=0
_$ (_TrimTrailingZeros (rtos 1510.0 2))
"1510"
DIMZIN=8
"1510"
                   (setq a (cdr a))
Nice idea pBe, but with DIMZIN=8:
_$ (supp0 (rtos 1510.0 2))
"151"
Thank you guys, that works. I knew it was simple as abc...
Now on my next routine... will post again if I get stuck. Thanks again!
