css Posted August 24, 2011 Posted August 24, 2011 In AutoCAD Map 3d 2012 there is a toolbar that has Cube View, Steering Wheel, Orbit, Pan and Zoom. How do I gop about disabling this toolbar? Quote
DANIEL Posted August 24, 2011 Posted August 24, 2011 you should be able to drag it away from its dock location and then close it with the little x in the corner. Quote
johnseg11 Posted August 24, 2011 Posted August 24, 2011 You can disable cube view on the command line. type: NAVVCUBE at the command prompt, then set it to off. The bar below the cube view can be turned off with the X in upper right corner. Quote
nestly Posted August 25, 2011 Posted August 25, 2011 NAVBARDISPLAY 0 = OFF (stored in registry) Quote
