MMS Posted August 26, 2011 Posted August 26, 2011 I have problem with my code especially for create list multiple selection. I choose more than one object but the result still have one list. _$ GETDYNPROPS <Selection set: 1b> 0 nil 4 _$ Could someone give explanation where's wrong with my code. ;mencari data (defun getdynprops (obj / v) (vl-remove-if 'null (mapcar '(lambda (x) (if (setq v (vlax-variant-value (vla-get-value x))) (cons (vla-get-propertyname x) v))) (vlax-safearray->list (vlax-variant-value (vla-getdynamicblockproperties obj))))) ) ;-------------- (vl-load-com) (setq ss (ssget )) (setq i 0) ;(setq ssd (ssadd)) (setq LiSS '()) (repeat (sslength ss) (setq i i) (setq ename (ssname ss i)) (setq vevo (vlax-ename->vla-object ename)) (setq LVevo (cdr(car(getdynprops vevo)))) (setq LiVevo (cons LVevo LiSS)) (setq i (1+ i)) );repeat Quote
Lee Mac Posted August 26, 2011 Posted August 26, 2011 Change: (setq LiVevo (cons LVevo LiSS)) To: (setq LiSS (cons LVevo LiSS)) Then check the value of the 'LiSS' variable. Make sure you localise your variables though!! Quote
MMS Posted August 26, 2011 Author Posted August 26, 2011 Change: (setq LiVevo (cons LVevo LiSS)) To: (setq LiSS (cons LVevo LiSS)) Then check the value of the 'LiSS' variable. Make sure you localise your variables though!! Hi Lee, Thanks for your explanation. Done Quote
