djpoizon Posted August 26, 2011 Posted August 26, 2011 Hey there. I recently downloaded the Student version of Autodesk Inventor Professional 2012 for Windows 7 64Bit. The problem I have with installing this is that it will initialize, and it will get to the Features selection page. Now obviously, I want all the features Autodesk can offer with this program, but once I click the install button, it shows up with the progress bar, completes maybe 2 steps out of the 33 required steps. It then presents me with an Installation Failure screen. I have tried every option that I can possibly think of to fix this, mainly manually installing Microsoft .Net Framework 4, which a lot of people have told me to do, but I just can't get the program to install successfully. Can anyone offer any help with this please? I am very desperate to try this product, as i have been told that It would be very advantageous to have it for my next course in Technical Design. Please help ! Quote
JD Mather Posted August 27, 2011 Posted August 27, 2011 Did you turn off anti-virus and UAC before download (especially before install)? Quote
djpoizon Posted August 27, 2011 Author Posted August 27, 2011 (edited) i had UAC turned off, as for the antivirus, i use AVG and there is no option to turn off my antivirus, so that remains active unless i can find another way to turn it off.. (Edit) Still no luck with getting it installed. Also, still no luck with turning my antivirus off, unless I uninstall it just to install autodesk, and I'm not willing to try that. Edited August 28, 2011 by djpoizon Quote
cadgodintraining Posted September 10, 2011 Posted September 10, 2011 to temporarily disable AVG 2011 Open the AVG 2011 Control Center, by right-clicking on the AVG icon on task bar. Click on Open AVG User Interface. On the Menu Bar, click on Tools, then click Advanced Settings. In the screen which opens, scroll down to Temporarily disable AVG protection. Click on it to highlight and in the right hand pane, check the box for Temporarily disable AVG protection. Click Apply. In the next screen which opens, select 15 minutes from the drop down menu, then click the Disable real time protection button and click OK. To re-enable, just check Enable on the main GUI interface. You may also need to click Fix (enable becomes Fix if all components do not start). You and add disable time as needed 15 minutes is the default but when it gets down to 5 or so you can just bump it back to 15 ... Quote
Bishop Posted September 12, 2011 Posted September 12, 2011 I'll bet you ten bucks it's .NET Framework 4 that it's hanging up on. I spent SEVERAL hours fighting with this, before finally figuring out what I needed to do. Download the FULL installation package from Microsoft. It's like 42 or 48 MB or something. You probably won't be able to just run it to install, either. Create a folder in your root directory with a short name - something like c:\dotnet - and use WinRAR to extract the files to there. (It might work with other archive software, but WinRAR is what I use, so I know it works.) (Yes, I know the file was an .EXE, but it's a self-extracting archive that doesn't seem to actually self-extract.) Once you've got the files extracted, go to start --> programs --> accessories, and run Command Prompt AS ADMINISTRATOR. That's key. Gotta right click and choose run as administrator. Enter the following commands: cd\dotnet (Assuming that "dotnet" is the directory name you used - otherwise, substitute the correct name.) setup.exe /x64 (Have to have the /x64 tag - otherwise it won't work.) .NET Framework 4.0 will now install, and you will be able to successfully install Inventor. Good luck! Quote
rdharvey Posted September 13, 2011 Posted September 13, 2011 This is probably a stupid question but whats UAC :/ Quote
Tiger Posted September 13, 2011 Posted September 13, 2011 This is probably a stupid question but whats UAC :/ User Account Control, its in windows Vista and forward. A little box that always pops up asking Do you want to do this? Do you really want to do this? Are you really sure? How about an icecream instead? Extremely annoying. Quote
rdharvey Posted September 13, 2011 Posted September 13, 2011 ah! and how do you turn it off? in the control panel? i'm using win7 so i will need to turn it off. Quote
CADAsh25 Posted September 17, 2011 Posted September 17, 2011 Did this work? I am having the same problem. It's really annoying I have been downloading this software for almost 7 days straight. I keep having issues installing and just redownload the whole damn thing. Basically I get through the entire install and then on the last step it says the files are corrupt and please install a fresh download. It's really getting on my nerves. I have a project due on Monday and I would like to get this done Quote
JD Mather Posted September 17, 2011 Posted September 17, 2011 Where are you downloading? Student Community? Internet connection speed (actual - not advertised)? Search Google for the trial download site and DO NOT indicate student, but when you do the install use your student serial number. Quote
