Burton Ngoma Posted August 29, 2011 Posted August 29, 2011 How do i create a DTM using X,Y,Z Coordintes in AutoCAD Civil 3D? Quote
Organic Posted August 30, 2011 Posted August 30, 2011 That is a rather broad question with a fair few steps involved. Have you read the surface (dtm) and points tutorials here: http://docs.autodesk.com/CIV3D/2012/ENU/filesCTU/GUID-F6A629B7-EB6B-443A-91EE-491076F7144-36.htm ? Quote
Tyke Posted August 30, 2011 Posted August 30, 2011 As Dink said its a big subject and you need to read up on the basics so you understand what happens when you create a DTM. Are the points already in C3D? As Civil points or AutoCAd points or AutoCAD blocks? Do you have breaklines or must they first be produced? Lots of questions that need to be answered before you can proceed. We produce DTMs from various source objects and each variant need its own solution. With AutoCAD Civil 3D 2010 you could get the documentation as PDF and as hard copy. Quote
Burton Ngoma Posted August 31, 2011 Author Posted August 31, 2011 Thanx you for you replies guys. Well am carrying out a topo survey using a DGPS and i need to create a DTM with AutoCAD Civil 3D coz thats the software available to me at the moment. i will also try to look at those tutorials (thanx dink) Quote
