p_verwer Posted August 31, 2011 Posted August 31, 2011 (edited) Good Day, I have a Block (elevation of a typ. door) that has attributes on it, Door Number and Room Name. The door needs to be hatched so I put an associative hatch in, which works fine in block editor. When I type different names and numbers the hatch boundaries resize accordingly. My problem is when I close block editor and reinsert the block (or ATTSYNC) and edit the names and numbers, the hatch does not resize the boundaries of the new text. Is their another way of doing this or am I missing something?? Thanks! Edited August 31, 2011 by p_verwer Quote
p_verwer Posted September 1, 2011 Author Posted September 1, 2011 D3-DOOR.dwg If you go to block editor and change the tag name of either attribute the associative hatch works fine. It's once the block is in inserted, the hatch does not correspond with the text changing. Quote
