tem Posted October 12, 2008 Posted October 12, 2008 i copied image from PDF using snaphot tool and than had paste directly in drawing. i cant rotate the image. rotate tool just moves image, doesnot rotates around base point. how to resolve that problem? Quote
ILLZILLA Posted October 12, 2008 Posted October 12, 2008 I don't know if this would help but you could try and attach the image into the drawing instead of copy pasting it. Quote
tem Posted October 12, 2008 Author Posted October 12, 2008 i tryed but it seems pdf immage couldnot be added via insert command Quote
Cad64 Posted October 12, 2008 Posted October 12, 2008 When you copy and paste a pdf into your Cad file, it comes in as an OLE object. You can Move it and you can Scale it, but you can't Rotate it. So, if you need to Rotate it, you will have to convert the pdf image to jpg or tif or some format that can be brought into the drawing using the IMAGEATTACH command. Quote
cadvision Posted October 15, 2008 Posted October 15, 2008 rotate it before you copy from the source. I haven't confirmed, but if you select the OLE image can you go to properties & maybe enter a rotation of 90 degrees Quote
cadvision Posted October 15, 2008 Posted October 15, 2008 in AutoCAD 2009 I can confirm that when you paste the OLE you get to enter scale and rotation. Also you can use properties to change the rotation Quote
Cad64 Posted October 15, 2008 Posted October 15, 2008 in AutoCAD 2009 I can confirm that when you paste the OLE you get to enter scale and rotation. Also you can use properties to change the rotation Really? According to Autodesk, this is not possible. Autocad Services & Support - Rotating OLE Objects I have 2007 at home and 2008 at work, so I can't test this myself. Quote
munizba718 Posted April 21, 2016 Posted April 21, 2016 When you copy and paste a pdf into your Cad file, it comes in as an OLE object. You can Move it and you can Scale it, but you can't Rotate it. So, if you need to Rotate it, you will have to convert the pdf image to jpg or tif or some format that can be brought into the drawing using the IMAGEATTACH command. I don't believe this is true. I have pasted a pdf image into CAD and have been able to rotate it without any problems. Quote
Cad64 Posted April 21, 2016 Posted April 21, 2016 I don't believe this is true. I have pasted a pdf image into CAD and have been able to rotate it without any problems. You realize the post you are replying to is from 2008, right? And you are using Autocad 2016, not Autocad 2007 like I was at the time I posted that. Quote
TheCADnoob Posted April 22, 2016 Posted April 22, 2016 That awkward moment when you sit next to your props after time traveling. Quote
StArchitect Posted April 22, 2016 Posted April 22, 2016 lol throwback Friday. When I want to paste an image into a dwg I first open it in paint then Copy it then Special Paste it in AutoCAD. Now I'm curious, how the hell did you you find this post? Quote
MillerMG Posted April 27, 2016 Posted April 27, 2016 You realize the post you are replying to is from 2008, right? And you are using Autocad 2016, not Autocad 2007 like I was at the time I posted that. Quote
