matilla Posted September 5, 2011 Posted September 5, 2011 I am using Mac version of Autocad 2011. When I was editing a reference, I accidentally save and close the drawing. I re-open the drawing, it is stuck in the Reference Editor mode forever without any "save" or close" button. I tried all REFCLOSE, BCLOSE... nothing works. All experts, please help. I am handing in the drawing tomorrow. Appreciate your help very much! Matilla Quote
Cad64 Posted September 5, 2011 Posted September 5, 2011 How did you manage to do that? I just tried it and got a message at the command line that said "Drawing save not allowed during reference editing", which means it's impossible to do what you did. Unless it's a bug in the Mac version that allows you to save and close during reference editing? Try this. Open a new, blank drawing. Insert your drawing into the new drawing and then explode it. Quote
nestly Posted September 5, 2011 Posted September 5, 2011 I think regular AutoCAD also has/had the same problem if the drawing was closed while the block editor was open. There's a hotfix for 2012, and I also seem to recall that RECOVER could correct the issue. I'm sure that particular hotfix is not for Mac, but if the Mac version has RECOVER, I don't think it can hurt to try. Related Mac topics: http://forums.autodesk.com/t5/AutoCAD-for-Mac/Can-t-exit-block-view/td-p/2800090 http://forums.autodesk.com/t5/AutoCAD-for-Mac/exit-block-editor-no-saving-option/td-p/2832463 Quote
matilla Posted September 5, 2011 Author Posted September 5, 2011 tried RECOVER. After I reopen, it is still stuck within the editor. any other solution? Thanks!! Quote
Cad64 Posted September 5, 2011 Posted September 5, 2011 Did you try what I suggested? Try this. Open a new, blank drawing. Insert your drawing into the new drawing and then explode it. Quote
matilla Posted September 5, 2011 Author Posted September 5, 2011 i found out there is a hotfix online. I am trying. Thanks guys. Quote
