Eagi Posted September 6, 2011 Posted September 6, 2011 So... when working with Autocad text, using the find command to uncover an evasive strip of text is really practical, but sadly enough Magicads annotation-flags are not included under this commands search parameters... So my question is if anyone has an alternative to the Find command to be able to locate magicad text? best regards // Ed Quote
Eagi Posted September 13, 2011 Author Posted September 13, 2011 worth a try, but where would you suggest to enter the text search parameter, since all the Qselect options are found in drop-down menus it's sort of hard to find for example all the texts containing "S1-110" or something of the sort. Quote
Tiger Posted September 13, 2011 Posted September 13, 2011 With QSelect you can pick Contents as the properties and then you get to type in the Value field. You can also chooose a Wildcard match as a operator which might help you... or Filter - a bigger and more complete version of QSelect. Quote
klalle Posted January 21, 2014 Posted January 21, 2014 Well yes i have found a way! I have just got an pdf from magicad support that explains how to access the magicad specific objects through vba or C. from there it's easy to loop through all the objects and look for the textobject containing your text! See this post When i have time, i will make such a function if you dont know how to program it yourselves... /Kalle Quote
Tiger Posted January 21, 2014 Posted January 21, 2014 Kalle, while I appreciate your vigour in helping other with MagiCAD-troubles - digging up threads that are several years old, where the OP probably moved on a long time ago, is not really appreciated. If someone searches for MagiCAD on this forum, they'll find the first post where you linked the document. Quote
klalle Posted January 23, 2014 Posted January 23, 2014 Well sorry for that, but there is still no solution out there which lets you search magicad text... your method of using filter or qselect does not apply to magicad text objects even if they appear in the object-type as Magidimlines, and i'm guessing i'm not the only one searching for a solution! Quote
SLW210 Posted January 23, 2014 Posted January 23, 2014 Yet, whenever I have asked for an example of an object from Magicad, no one has posted anything. Makes it very hard to come up with a solution. Quote
