hello i m new at autocad.
can u tell me how can i place any diameter cirlcles at equal distances.
Regards
sachin
Can you provide us with a little more detail? What are you working on?
actually i m drawing the electrical control panel drawings. so, in the drawings all the contactors and trmial boxes are drawn by circles in ranctangle.
so, i m trying to draw that one but i cant get the exact distance between circles.
You could draw one circle then use the ARRAY command to create the others.
o yes, thank you very much. struggling from morning. 1 more thing that when i draw line to joint any picture(square, rectangle, circle), line seems not connect at the end. i have to zoom and then using stratch command, i can connect. why is like that? i was using PSPICE AND METLAB in old company it was pretty easy to join line.
Osnaps like endpoint, intersection, midpoint, center, quadrant, etc. allow for precision placement of geometry.
