bjenk8100 Posted September 7, 2011 Posted September 7, 2011 Hello, I often have multiple viewports with different scales. I like to annotate in model space. I also like to do everything else in model space minus title bar and detail names/numbers. I am trying to put revision clouds on things in different viewports but they change arc sized per viewport. Can you make revision clouds annotative. Currently, I have to change arc size per viewport which gets annoying and confusing sometimes. Any feedback greatly appreciated. Tnx Quote
JBullseye74 Posted September 7, 2011 Posted September 7, 2011 I know exactly what you mean i work in the same manner and also have this problem. There is nothing in the cloud comand to make it annotative, i have in the past clouded in paperspace so you don't have to keep changing the Arc scale.... but i don't like to. You could possibly make a block ad make that annotative but this wouldn't be very flexible in terms or manipulating size etc. Oh actually why don't you do the cloud in paper space and then CHSPACE it into the viewport!! :-) Quote
nestly Posted September 7, 2011 Posted September 7, 2011 Here are two thread where the revcloud is supposed to be sized according to the scale, but I can't get either to honor the scale. http://forums.augi.com/showthread.php?t=91499 http://forums.augi.com/showthread.php?t=125926 Quote
