Hi,
I am a new user (using Autocad 2006). My problem is I have been given a drawing file that I need to modify but it was drawn in inches, I have always worked in mm's. Can I convert the origional drawing to mm's??
Many thanks for any help.
Regards
Roy
One option would be to scale the whole drawing by 25.4 (1'=25.4mm).
That's the easiest way! If you need to scale back, then scale it by .03937 (the equivalent of 1/25.4).
Hi,
Many thanks for your help. It's easy when you know how.
Regards
Roy
It's easy as long as you aren't going to edit it too. Then the real fun begins.
or scale back using the Reference option. So much easier to type. :)
I will need to modify th drawing in mm's. Is that a problem? or do I have to redraw?
Regards
Roy
That works too!
Regards
Roy
Once you scale it up, you can modify it to your heart's delight. If you need to return it back to the original CAD person, then you could scale it back down to imperial as a kind gesture.
Many thanks for your help. That will save a lot of work.
Regards
roy
You might consider the 'dimstyle' command.
You could change the dimstyle adding alternate dimension(s).
Add a suffix [mm] as shown.
Edited by Tankman
