How to create STEP file from an assembly on Inventor 2010
Can anyone point me to the right direction or links on How to create STEP file from an assembly on Inventor 2010
Thanks in advance
Click the Inventor icon "I" then select Save as > Save copy as > Save as Type > you can chose which one you like.
Thank you CAnnondale. That works. however, I noticed that the assembly does not convert to solid, it still show all the components. What I wanted to to turn these assembly into solid (1 pieces) and in STEP file and send to my client so they cannot alter but use the assembly to incorporate it into their assembly. How can I do these.
Should I shrinkwrap it first before convert to STEP file?
Shrinkwrap or Derived Component (which is really what shrinkwrap is) to convert assembly to one solid.
Then save as STEP.
Shrinkwrap gives you the added functionality of automated removal of small features and "flood fill" of internal cavitities if desired.
Thank you very much for all your help. I also have another thread posted on Vault with log in issue, could you please help.
