block names called *124
I have blocks in my drawing that has name *u207. But I cant just Insert these block or change it. How does "*" command works?
assuming MEP works the same as AutoCAD they are anonymous blocks. They are very difficult to control although there are a number of LISP routines in this forum that will make them accessible.
Search for anonymous blocks or check the similar threads below.
ok thanks. And I need lisp to control them right?. Is there anyway to see at least the folder that it comes from?. I'll search for anonymous blocks.
I believe *u can be created from dynamic blocks, you may want to search for that as well as anonymous blocks.
Corrected, my mind and fingers do not seem connected properly today.
Edited by SLW210
Brain lock-up
