I have a file imported from someone else, I think it was made in Tekla. The objects are polyface meshes. I need to do some isometric flatshots of certain areas, but Flatshot appears not to work on Polyface Meshes.
I have read some other posts about lisp routines that convert meshes to solids. They seem to have varying success and I don't need a solid for any other reason than Flatshot.
Try the THICKEN command on the mesh first. Then try FLATSHOT. If that doesn't work you'll have to find a LISP but I've never had any good luck with them in the past. Or you could try the good 'ol fashioned FLATTEN Express Tool command.
