baker Posted September 15, 2011 Posted September 15, 2011 Is there any ScriptPro for Windows Vista 64-bit? Quote
BlackBox Posted September 15, 2011 Posted September 15, 2011 Try this: Autodesk Labs ScriptPro is your friend. Just saying. Quote
baker Posted September 15, 2011 Author Posted September 15, 2011 odd the one i downloaded from the Adesk site 3 weeks ago didnt work on vista 64.. i'll try this one. Quote
BlackBox Posted September 15, 2011 Posted September 15, 2011 From the ReadMe.txt in the above linked download: System Requirements ------------------- This application has been tested with AutoCAD 2008 onwards. It will use the version of AutoCAD most recently used on the system. To select a particular version of AutoCAD for use with the tool, simply start and close that version prior to using it. A pre-built version of the application has been provided which should work on 32- and 64-bit Windows systems. The application requires the .NET Framework 3.5 or above. The application has not been tested with all AutoCAD-based products, but should work (see "Feedback", below, otherwise). The source code has been provided as a Visual Studio 2008 project containing C# code (not required to run the tool). This application makes use of "Microsoft Ribbon for WPF October 2010". This only needs to be installed if you wish to work with the source project: http://www.microsoft.com/downloads/en/details.aspx?FamilyID=2bfc3187-74aa-4154-a670-76ef8bc2a0b4 ... Quote
