Hello,
Is it possible to run a script or lisp by a Hyperlink. The idea is to place a rectangle or a text with a hyperlink that runs a script to turn layer groups on or off.
Thanks
PmxCAD
I could be wrong, but I believe that adding a hyperlink of a valid file path to either a script, or lisp file will only open the linked file as if double clicked from Windows Explorer.
I suspect that you'll need to employ a custom lisp command that will prompt you to select a linked entity, and provided the hyperlink is valid (read the file exists), the code will conditionally load the script, or lisp file respectively.
Why not use toolbars instead. but thats a good question though. how would you invoke a lisp besides typing/toolbar/menus?
You can however hyperlink a *.lnk file with this line as Target:
 "C:\Program Files\AutoCAD 2009\acad.exe" "Trial.dwg" /b "c:\run"
where run isthe script name. but link will open a new session of cad, I guess you may need the proper switch i.e. /t /c etc.. to launch the script on an open drawing.
a DIESEL expression perhaps?
Select an entity, check for URL, then check that URL (filepath) is for a valid file. Upon those checks all returning T Non-Nil, CONDitionally filter for, and *LOAD the applicable file extention.
Pseudo code:
(defun c:URLLOAD  (/ e url flag ext)
 ;; © RenderMan, 2011
 (princ "\rURLLOAD ")
 (vl-load-com)
 (if (and (setq e (car (entsel "\nSelect entity to load URL: ")))
          (setq url (geturl e))
          (setq flag (/= "" url))
          (findfile url))
   (cond
     ((= ".LSP" (setq ext (strcase (vl-filename-extension url))))
      (load url))
     ((= ".SCR" ext)
      (command "._script" url))
     ((prompt "\n** Invalid file extention ** ")))
   (cond
     (flag (prompt (strcat "\n** \"" url "\" cannot be found ** ")))
     (e (prompt "\n** Invalid url ** "))
     ((prompt "\n** Nothing selected ** "))))
 (princ))
** Note - Code written from memory, on smartphone. I may have some mistakes/ typos. :oops: LoL
Edit: Code revised
HTH
Edited by BlackBox
Hello,
Autocad returns: ; error: too few arguments
Iàm not into LISP can you help? I put the pad to the file between the "" marks, is this ok?
thanks,
pmxcad
Try:
(defun c:UrlLoad (/ e url flag ext)
 (vl-load-com)
   (setq flag (/= "" (setq url (geturl e))))
   (findfile url)
   (cond ((= ".LSP" (setq ext (strcase (vl-filename-extension url))))
   (load url)
  ((= ".SCR" ext) (command "_.SCRIPT" url))
   (cond (url
  (flag (prompt "\n** Invalid url ** "))
HofCAD CSI.
Edited by HofCAD
Ooookay.........,
But where to put the pad?
Like: D:\Mijn documenten\lsp\LAYER INST OFF.SCR
THANKS
In the HYPERLINK dialog box you see:
'Text to Display'
and
'Type the File or Web Page Name'.
In 'Text to Display' you put: LAYER INST OFF
In 'Type the File or Web Page Name' you put: D:\Mijn documenten\lsp\LAYER INST OFF.SCR
HofCAD CSI.
Select an entity, check for URL, then check that URL (filepath) is for a valid file. Upon those checks all returning T, CONDitionally filter for, and *LOAD the applicable file extention.
Pseudo code:
(defun c:URLLOAD ( \ e url flag ext)
 (vl-load-com)....
Nice idea Renderman, I havent thought of that. my line of thinking was run a script from an outside source so to speak.
Cool beans
Cool beans
Thanks pBe :); I did notice some errors (now that I'm on my work laptop instead of smartphone *doh*), and have revised the code. It works like a charm now! :wink:
I've tested both *.LSP, and *.SCR successfully.
Example:
Command: (seturl (car (entsel)) (findfile "acaddoc.lsp"))
Select object: nil
Command: urlload
URLLOAD
Loading ACADDOC.lsp...
Command:
OK,
Works perfect. Came something else on my mind.
Lets take a block with multiline attributes. Name one attribute SCRIPT. And when inserting that block, fill in a script data to that attribute, and run that script with a lisp bij selecting it. Reason, always keep the script in the drawing.
Pmxcad
Interesting idea, I can't wait to see it... :) :popcorn:
  • 8 years later...
HI
ITS PASSED SO LONG BUT I CURIOUS,  ITS EXAMINED WITH FAVOR RESULT 🤔
On 9/20/2011 at 8:32 PM, pmxcad said:
OK,
Pmxcad
HI
IS THAT POSSIBLE TO DO?
