Lee Mac Posted September 20, 2011 Posted September 20, 2011 Yup.. your new code here used a different approach. Block names. Nice Cheers Quote
BlackBox Posted September 20, 2011 Posted September 20, 2011 Thanks for the info Renderman. Happy to help *MMmmm Beer* Quote
mrharris78 Posted September 21, 2011 Author Posted September 21, 2011 Cheers guys, Overwhelming response!! Way beyond my Lisp/Vlisp knowledge, but it's a good learning tool! CHEERS! Quote
nod684 Posted February 7, 2013 Posted February 7, 2013 how about if i want all attributes in a certain layer? can i use this? what part should be change? Quote
pBe Posted February 7, 2013 Posted February 7, 2013 how about if i want all attributes in a certain layer? can i use this?what part should be change? Are you referring ssget filter? In an ideal world all entities on a "BLOCK" are on layer "0" , that way it would inherit the properties of the layer it resides. At any rate, it would be impossible to capture these "attributes" thru SSGET filter alone. You may need to dig deep into the block (tblobjename/vlax-for) to determine the layer which the attdef resides , not counting the "fudge" attdef's in which case you need to iterate thru every selected attribute block. HTH Quote
nod684 Posted February 13, 2013 Posted February 13, 2013 thanks for the reply pBe...assuming i know the name of the block with attributes and all the attributes in that block are in layer 0. is it possible? Quote
