musyas Posted October 14, 2008 Posted October 14, 2008 About the Standard size of the Window openings in Bedroom, T & B and Others.??? Anyone knows. Quote
hay123 Posted October 14, 2008 Posted October 14, 2008 Not sure what the question is? If you can find a window manufactures web site, they often have technical brochers that can be downloaded, with their standard window and opening specifications. Quote
Dipali Posted October 14, 2008 Posted October 14, 2008 not sure exactly what u need. but the minimum size of window opening should be atleast 10% of the floor area of that room. this is minimum not the standard Quote
musyas Posted October 14, 2008 Author Posted October 14, 2008 No. That's not what i looking for im asking what is the Standard Size in (mm) of the Window opening in Bedroom and T&B? what i'm looking is standard Length of the Window in a every given room. Quote
PS_Port Posted October 14, 2008 Posted October 14, 2008 musyas, I believe their is no "standard size" window for a bedroom. A typical size window would vary form country to country.. Then there is the look that your after, aluminium, wood, single hung, double sliding, fixed/sliding, double sliding. have a look at window manufacturer's websites for details. Also as Dipali mentioned there are minimum codes regarding light and ventilation that apply to habitable rooms, but again this would vary from country to country. Here is one from Australia might help. http://www.stegbar.com.au/pdf/Stegbar-Aluminium.pdf (For bedrooms I see a lot of approx. 1500mm high x 1800 wide, 2100 head height.- in standard spec. houses) Quote
Tankman Posted October 14, 2008 Posted October 14, 2008 If you can find a window manufactures web site, they often have technical brochers that can be downloaded, with their standard window and opening specifications. And, windows can be custom built to almost any configuration or size. www.pellaADM.com ~ Downloadable *.dwg files, doors 'n windows. Quote
ReMark Posted October 14, 2008 Posted October 14, 2008 In the United States emergency egress is required in every bedroom and in every basement with inhabitable space. Windows used for emergency egress must have a sill within 44" of the floor. They also must have a net clear opening area of 20" (min. width) and 24" (min. height). You should consult your building and fire codes to determine what minimum requirements govern in the state/country you live in. Quote
