seegs Posted September 21, 2011 Posted September 21, 2011 (edited) Howdee Yall I'm a beginner in Autolisp, and have written a program to insert any block into any drawing. Its kinda crude, but that doesnt matter. It actually works really well. The only problem is, after I have run it, the next time I use a drawing connected to a database, it loses the connection. And I can't get it back unless I actually change the folder name with the lisp program. This is the only problem, (as far as I know) but I would really like it to be fixed. Here is the program: (defun c:blocks () (command "insert" "S:\\9-AutoCAD\\Blocks\\Blocks_for_Tool_Palettes.dwg" "0,0" "0.00001" "0.00001" "0" ) (command "erase" "l" "") (princ) (alert "Click OK then type in the code for the corresponding block you want from the following: B1= [modelspace]_Existing MH not shown on Council GIS B2= [modelspace]_Connectivity different to that shown on Council GIS B3= [modelspace]_MH in different location to that shown on Council GIS B4= [modelspace]_Install New 600mm dia. Access Chamber B5= [modelspace]_Existing manhole B6= [modelspace]_Node B7= [modelspace]_New access chamber B8= [modelspace]_Existing access chamber B9= [modelspace]_House names B10= [modelspace]_Road names B11= [modelspace]_Pipe script B12= [modelspace]_Rehab assessment number B13= [paperspace]_STAMP_Tender B14= [paperspace]_STAMP_Preliminary B15= [paperspace]_STAMP_Issued for Construction B16= [paperspace]_STAMP_As built B17= [paperspace]_STAMP_Revision Stamp B18= [paperspace]_Manhole B19= [paperspace]_Node B20= [paperspace]_Access Chamber" ) (setq usercode (strcase (getstring "\nEnter code: ") nil)) (cond ((= "B1" usercode) (and (setq userinsertionpoint (getpoint "\nSpecify insertion point:")) (command "-insert" "Existing MH not shown on Council GIS" userinsertionpoint "" "" ) ) ) ((= "B2" usercode) (and (setq userinsertionpoint (getpoint "\nSpecify insertion point:")) (command "-insert" "Connectivity different to that shown on GIS" userinsertionpoint "" "" ) ) ) ((= "B3" usercode) (and (setq userinsertionpoint (getpoint "\nSpecify insertion point:")) (command "-insert" "MH in different location to that shown on Council GIS" userinsertionpoint "" "" ) ) ) ((= "B4" usercode) (and (setq userinsertionpoint (getpoint "\nSpecify insertion point:")) (command "-insert" "Install New 600mm dia. Access Chamber" userinsertionpoint "" "" ) ) ) ((= "B5" usercode) (and (and (setq userinsertionpoint (getpoint "\nSpecify insertion point:") ) (command "-insert" "_ManholeExisting" "S" "25.4" userinsertionpoint "" "" "" ) ) ) ) ((= "B6" usercode) (and (setq userinsertionpoint (getpoint "\nSpecify insertion point:") ) ) (command "-insert" "Model View Node" "s" "0.85" userinsertionpoint "" "" "" ) ) ((= "B7" usercode) (and (setq userinsertionpoint (getpoint "\nSpecify insertion point:") ) (command "-insert" "New Access Chamber" userinsertionpoint "" "" "" ) ) ) ((= "B8" usercode) (and (setq userinsertionpoint (getpoint "\nSpecify insertion point:") ) (command "-insert" "Existing Access Chamber" userinsertionpoint "" "" "" ) ) ) ((= "B9" usercode) (and (setq userinsertionpoint (getpoint "\nSpecify insertion point:")) (command "-insert" "ACMAP_ANN_TEMPLATE_House Names" userinsertionpoint "20" "20" "0" "House Names" ) ) ) ((= "B10" usercode) (and (setq userinsertionpoint (getpoint "\nSpecify insertion point:")) (command "-insert" "ACMAP_ANN_TEMPLATE_Road_Name" userinsertionpoint "20" "20" "0" "Road_Name" ) ) ) ((= "B11" usercode) (and (setq userinsertionpoint (getpoint "\nSpecify insertion point:")) (command "-insert" "ACMAP_ANN_TEMPLATE_Pipe Script" userinsertionpoint "20" "20" "0" "Pipe Script" ) ) ) ((= "B12" usercode) (and (setq userinsertionpoint (getpoint "\nSpecify insertion point:")) (command "-insert" "ACMAP_ANN_TEMPLATE_Rehab Assessment No" userinsertionpoint "20" "20" "0" "Rehab Assessment No" ) ) ) ((= "B13" usercode) (and (setq userinsertionpoint (getpoint "\nSpecify insertion point:")) (command "-insert" "TENDER" userinsertionpoint "" "") ) ) ((= "B14" usercode) (command "-insert" "PRELIMINARY" "s" "0.025" "70,60" "" "") ) ((= "B15" usercode) (command "-insert" "Issued for Construction" "s" "0.025" "70,60" "" "" ) ) ((= "B16" usercode) (and (setq userinsertionpoint (getpoint "\nSpecify insertion point:")) (command "-insert" "AS BUILT" userinsertionpoint "" "") ) ) ((= "B17" usercode) (and (setq userinsertionpoint (getpoint "\nSpecify insertion point:")) (command "-insert" "Revised Stamp" userinsertionpoint "" "" "" ) ) ) ((= "B18" usercode) (and (setq userinsertionpoint (getpoint "\nSpecify insertion point:") ) (command "-insert" "Manhole Paperspace2" userinsertionpoint "1" "1" "0" "" ) ) ) ((= "B19" usercode) (and (setq userinsertionpoint (getpoint "\nSpecify insertion point:") ) (command "-insert" "Node Paperspace" userinsertionpoint "1" "1" "0" "" ) ) ) ((= "B20" usercode) (and (setq userinsertionpoint (getpoint "\nSpecify insertion point:") ) (command "-insert" "Access Chamber Paperspace" userinsertionpoint "1" "1" "0" "" ) ) ) (T (alert "That is not a valid code")) ) (command "_.purge" "_all" "" "_no") (command "_.purge" "_all" "" "_no") (command "_.purge" "_all" "" "_no") (command "_.purge" "_all" "" "_no") (princ "finished") (princ) ) Edited September 22, 2011 by seegs Posting Nazis Quote
BIGAL Posted September 21, 2011 Posted September 21, 2011 I can here the screaming TOOLPALLETES Typing a name is a bit old fashioned I use menus and sld images which is old fashioned but better than remembering a block name we have around 200+ blocks Quote
SLW210 Posted September 21, 2011 Posted September 21, 2011 seegs, Please read the CODE POSTING GUIDELINES and edit your post. Quote
seegs Posted September 21, 2011 Author Posted September 21, 2011 Good point, & most of them are in tool palettes, just scattered around with obsolete blocks. I guess sorting them into one would be the way to go. Just thought I'd try a hardish lisp routine to up my skills. BTW what are these menus & sld images about? Quote
BIGAL Posted September 22, 2011 Posted September 22, 2011 Its the same as the hatch patterns in Hatch but with a picture of your blocks you can have multi page under 1 heading and have lots of headings, I will try to find previous post this has an example http://www.cadtutor.net/forum/showthread.php?30342-Looking-for-a-custom-program-to-Insert-blocks-from-a-cad-library&highlight=Slide Quote
SLW210 Posted September 22, 2011 Posted September 22, 2011 seegs, Please read the CODE POSTING GUIDELINES and edit your post. Please edit your post. Quote
