ketxu Posted September 23, 2011 Posted September 23, 2011 Hi all.Please help me one simple problem. I use getangle (or getorient) to get an angle (angbase and angdir changed to suite already), and then check it value to decide direction to rotate. How could i make it return negative also ? Ex : (getangle) =>type -20 => return :-0.349066 , not 5.93412 ? I don't want use getstring, then check "-" or sth similar, since it no support pick two point Please help me, i can't control my brain now Thanks for reading Quote
pBe Posted September 23, 2011 Posted September 23, 2011 (edited) in cases like that and degrees input cannot be help, i normally use getreal/dtr (setq ang (if (minusp (setq i (getreal "\nEnter Angle: "))) (* pi (/ (+ 360 i) 180.00)) (* pi (/ i 180.0))) ) But it doesnt help with your question though This perhaps? (defun c:test (/ ang) (setq ang (getreal "\nEnter Angle:<Enter to pick two points>: ")) (if (= ang nil) (setq ang (getangle "Pick points for Angle: ")) (if (minusp ang) (* pi (/ (+ 360 ang) 180.00)) (* pi (/ ang 180.0)) ) ) ) Edited September 23, 2011 by pBe Quote
Lee Mac Posted September 23, 2011 Posted September 23, 2011 My version: (defun LM:2piAngle ( a ) (if (minusp (setq a (rem (+ pi pi a) (+ pi pi)))) (LM:2piAngle a) a ) ) _$ (LM:2piAngle -0.349066) 5.93412 Or, for angles (-2pi (defun LM:2piAngle ( a ) (rem (+ pi pi a) (+ pi pi))) Quote
ketxu Posted September 23, 2011 Author Posted September 23, 2011 Thanks very much to Lee and pBe for helping. Sorry for my English, i feel there is a misunderstanding. I just want when i input an negative (ex -20), it will return -0.349066 , not 5.93412 like getangle did. SO i will try to modify a little two defun above ^^ I only want to ask can it be done by getang or getorient ^^ Quote
Lee Mac Posted September 23, 2011 Posted September 23, 2011 Thanks very much to Lee and pBe for helping. Sorry for my English, i feel there is a misunderstanding. I just want when i input an negative (ex -20), it will return -0.349066 , not 5.93412 like getangle did. SO i will try to modify a little two defun above ^^ I only want to ask can it be done by getang or getorient ^^ Why do you need it to specifically return the negative angle? Both angles are identical. Quote
ketxu Posted September 24, 2011 Author Posted September 24, 2011 Ah, actualy i'm trying to decide direction to array polar (base on qjchen idea). Please see my post and red code of qjchen to understand my explaination. Srr for my poor E With negative number, i want it go clockwise.But problem is ang allway return positive number, so i ask can it be solved by getangle anymore(lazy)? or i've change the way of get angle, or change two red code line ^^ Preview : Open Source : ;Many thank to qjchen again (vl-load-com) (defun c:par( / ang angnow gr oang p0 px px1 ss ss1 cc oldAng ans) (grtext -1 "Dynamic PArray @Ketxu") (setq m:err *error* *error* err) (command "undo" "be") (setq oldAng (getvar "angbase")) (if (and (setq ss (ST:SS->List-Vla (ssget)) p0 (getpoint "\nT\U+00E2m quay : :") px (getpoint p0 "\n\U+0110\U+01B0\U+1EDDng c\U+01A1 s\U+1EDF ::") ) ) (progn (grdraw p0 px 1) (setvar "angbase" (angle p0 px)) (setq cc (_circle p0 (distance p0 px)) ang (getangle p0 "\nG\U+00F3c Array :") s (/ (getvar "viewsize") (cadr (getvar "SCREENSIZE"))) ) (cond ((ST:Check-Exist '("AcDbText" "AcDbMText") (mapcar 'vla-get-objectname ss)) (setq ans (strcase(getstring "Copy t\U+0103ng Text ? < K > :"))) (cond ((not (or (= ans "K")(= ans ""))) (or #num (setq #num 1)) (setq #num (cond ((getint (strcat "\nGia s\U+1ED1 < " (rtos #num 2 0) " > :")))(#num)) inc T) ) ) ) ) (prompt "\nPick \U+0111i\U+1EC3m cu\U+1ED1i c\U+00F9ng :") (while (= (car (setq gr (grread nil 5 0))) 5) (if ss1 (mapcar 'vla-delete ss1)) (redraw) (setq angnow (angle p0 (cadr gr)) g (trans (cadr gr) 1 3) ) (grvecs (LM:GrText (rtos (/ (* angnow 180) pi) 2 0) 3) ( (lambda ( r x y ) (list (list r 0. 0. x ) (list 0. r 0. y ) (list 0. 0. r 0.) (list 0. 0. 0. 1.) ) ) s (+ (car g) (* 15 s)) (- (cadr g) (* 31 s)) ) ) [color=red](if (and (< ang 0)(> angnow 0)) (setq angnow (- angnow (* 2 pi))))[/color] [color=red] (if (and (> ang 0)(< angnow 0)) (setq angnow (+ (* 2 pi) angnow)))[/color] (setq ss1 (_copyCC ss (fix (/ angnow ang)) p0 ang inc #num)) (grdraw:arc p0 (/ (getvar "viewsize") 4.0) (angle p0 px) angnow) ) (entdel cc) (setvar "angbase" oldAng) ) ) (command "undo" "en") (princ) ) ;;; =======================================================================; ;;; by qjchen, copy ss according to the direction and vector ; ;;; =======================================================================; (defun _copyCC (sslst n cen ang inc num / i obj1 ss xobj lst number) (foreach xobj sslst (setq i 1) (cond ((and (wcmatch (vla-get-objectname xobj) "AcDbText,AcDbMText") inc num) (cond ((= 'REAL (type (setq number (last (setq lst (ST:String-GetNumber (vla-get-textstring xobj))))))) (setq isReal T)) (T (setq isReal nil)) ) (setq isText T) ) ;Text Object (T setq isText nil) ) (repeat n (setq obj1 (vla-copy xobj)) (Vla-rotate obj1 (vlax-3d-point cen) (* ang i)) (if (and isText (wcmatch (vla-get-objectname xobj) "AcDbText,AcDbMText") inc num) (vla-put-textstring obj1 (strcat (car lst) (rtos (setq number (+ num number)) 2 (if isReal 1 0))(cadr lst)))) (setq i (1+ i) ss (cons obj1 ss)) ) ) ss ) ;;; =======================================================================; ;;; @Ketxu Make Circle Temp ; ;;; =======================================================================; (defun _circle (p0 r / ent) (redraw (setq ent(entmakex (list (cons 0 "CIRCLE")(cons 10 (trans p0 1 0))(cons 40 r)))) 3) ent) (defun RtD (rad) ; converts radian to degree (/ (* rad 180) pi) );defun ;;; =======================================================================; ;;; Check List Item Exist in Other List @Ketxu ; ;;; =======================================================================; (defun ST:Check-Exist(lst1 lst2)(and (vl-remove nil (mapcar '(lambda(x)(vl-position x lst2)) lst1)))) ;;; =======================================================================; ;;; Selection to list VLA @Ketxu ; ;;; =======================================================================; (defun ST:SS->List-Vla (ss / n e l) (setq n (sslength ss)) (while (setq e (ssname ss (setq n (1- n)))) (setq l (cons (vlax-ename->vla-object e) l)) ) ) (defun ST:Ss-Delete (ss / i) (mapcar 'vla-delete (ST:SS->List-Vla ss)) ) ;;; =======================================================================; ;;; grdraw circle arc ; ;;; =======================================================================; (defun grdraw:arc(cen r ang angadd / angdiv n) (grdraw cen (polar cen ang r) 3 1) (grdraw cen (polar cen (+ ang angadd) r) 3 1) (setq n 100 angdiv (/ angadd n)) (repeat n (grdraw (polar cen ang r)(polar cen (setq ang (+ ang angdiv)) r) 1 1) ) ) (defun ST:String-GetNumber (str / i j dau cuoi tmp tmp1 tmp2 num) (setq lst (vl-string->list str) i -1 j (strlen str)) (list (setq tmp1 (vl-list->string (reverse (while (not (or (<= 48 (setq tmp (nth (setq i (1+ i)) lst)) 57) (>= i j))) (setq dau (cons tmp dau)))))) (setq tmp2(vl-list->string (while (not (or (<= 48 (setq tmp (nth (setq j (1- j)) lst)) 57) (<= j i))) (setq cuoi (cons tmp cuoi))))) (if (vl-string-search "." (setq num (vl-string-left-trim tmp1 (vl-string-right-trim tmp2 str)))) (atof num) (atoi num)) ) ) ;;; =======================================================================; ;;; Error del selection @Ketxu ; ;;; =======================================================================; (defun err (msg) (if ss1 (mapcar 'vla-delete ss1)) (if cc (entdel cc)) (if oldAng (setvar "angbase" oldAng)) (setq *error* m:err m:err nil) ) ;;-----------------------=={ GrText }==-----------------------;; ;; ;; ;; Returns a grvecs pixel vector list relative to the origin ;; ;; encoding the supplied string. ;; ;;------------------------------------------------------------;; ;; Author: Lee Mac, Copyright © 2011 - www.lee-mac.com ;; ;;------------------------------------------------------------;; ;; With thanks to ElpanovEvgeniy for the method of vector ;; ;; encoding to save me a lot of typing ;; ;;------------------------------------------------------------;; ;; Arguments: ;; ;; str - String to be expressed in vector list format. ;; ;; col - Colour of Text (ACI Colour). ;; ;;------------------------------------------------------------;; ;; Returns: GrVecs Pixel Vector List relative to the Origin ;; ;;------------------------------------------------------------;; ;; Version 1.0 - 19-03-2011 ;; ;;------------------------------------------------------------;; (defun LM:GrText ( str col / c i l v y ) ;@Lee Mac (setq v '( (" ") ("\t") ("!" 45 45 65 135) ("\"" 104 134 107 137) ("#" 43 63 46 66 84 94 87 97 115 135 118 138 72 78 103 109) ("$" 25 35 52 52 43 47 58 78 83 87 92 112 123 127 118 118 135 135) ("%" 52 52 63 63 74 74 85 85 96 96 107 107 118 118 129 129 47 48 67 68 56 56 59 59 113 114 133 134 122 122 125 125) ("&" 43 46 49 49 52 72 57 58 67 68 76 76 79 79 83 83 85 85 94 94 103 123 134 136 127 127) ("'" 105 135) ("(" 17 17 26 36 45 105 116 126 137 137) (")" 14 14 25 35 46 106 115 125 134 134) ("*" 73 74 76 77 84 86 92 98 104 106 113 114 116 117) ("+" 55 115 82 84 86 88) ("," 34 35 45 46 55 57) ("-" 83 88) ("." 45 46 55 56) ("/" 52 52 63 63 74 74 85 85 96 96 107 107 118 118 129 129) ("0" 44 47 134 137 53 123 58 128) ("1" 44 48 124 125 56 136) ("2" 43 48 53 53 64 64 75 75 86 86 97 97 108 128 134 137 123 123) ("3" 53 53 44 47 58 88 95 97 108 128 134 137 123 123) ("4" 46 48 57 137 78 78 73 76 83 83 94 94 105 115 126 126) ("5" 53 53 44 47 58 88 94 97 93 133 134 138) ("6" 44 47 58 88 95 97 84 84 53 113 124 124 135 137) ("7" 44 54 65 75 86 96 107 117 128 138 133 137 123 123) ("8" 44 47 94 97 134 137 53 83 58 88 103 123 108 128) ("9" 44 46 57 57 68 128 97 97 84 86 134 137 93 123) (":" 45 46 55 56 95 96 105 106) (";" 34 35 45 46 55 57 95 96 105 106) ("<" 47 47 56 56 65 65 74 74 83 83 94 94 105 105 116 116 127 127) ("=" 73 78 93 98) (">" 43 43 54 54 65 65 76 76 87 87 96 96 105 105 114 114 123 123) ("?" 45 45 65 75 86 86 97 97 108 128 134 137 123 123) ("@" 34 38 43 43 52 112 123 123 134 137 128 128 79 119 68 68 65 66 105 106 77 107 74 94) ("A" 41 43 47 49 52 62 58 68 73 77 83 93 87 97 104 114 106 116 125 135 133 134) ("B" 42 47 53 123 58 88 108 128 94 97 132 137) ("C" 44 47 53 53 58 58 62 112 123 123 134 136 127 127 108 138) ("D" 42 46 57 57 127 127 132 136 68 118 53 123) ("E" 42 48 58 58 94 95 86 106 132 137 128 138 53 123) ("F" 42 45 94 95 86 106 132 137 128 138 53 123) ("G" 44 47 53 53 58 78 86 89 62 112 123 123 134 136 127 127 108 138) ("H" 41 43 47 49 131 133 137 139 93 97 52 122 58 128) ("I" 43 47 133 137 55 125) ("J" 52 62 43 46 57 127 135 139) ("K" 42 44 48 49 132 134 136 138 53 123 84 85 95 95 106 116 127 127 76 76 67 67 58 58) ("L" 42 47 48 58 53 123 132 135) ("M" 41 43 47 49 52 122 58 128 131 132 138 139 103 113 107 117 84 94 86 96 65 75) ("N" 41 44 131 132 136 139 52 122 48 128 113 113 94 104 85 85 66 76 57 57) ("O" 44 46 53 53 57 57 123 123 127 127 134 136 62 112 68 118) ("P" 42 45 84 87 132 137 53 123 98 128) ("Q" 134 136 123 123 127 127 112 62 118 68 53 53 57 57 44 46 35 36 23 24 27 28) ("R" 42 44 48 49 132 137 123 53 128 98 84 87 76 76 67 67 58 58) ("S" 42 62 53 53 44 47 58 78 86 87 93 95 102 122 133 136 127 127 118 138) ("T" 43 47 55 125 132 138 131 121 139 129) ("U" 44 46 52 53 57 58 62 122 68 128 131 133 137 139) ("V" 45 55 64 74 66 76 83 103 87 107 112 122 118 128 131 133 137 139) ("W" 43 63 47 67 72 92 74 94 76 96 78 98 101 121 105 115 109 129 131 132 138 139) ("X" 41 43 47 49 131 133 137 139 52 52 58 58 63 63 67 67 74 74 76 76 85 95 104 104 106 106 113 113 117 117 122 122 128 128) ("Y" 43 47 55 85 94 94 96 96 103 113 107 117 122 122 128 128 131 133 137 139) ("Z" 122 122 58 58 132 138 42 48 128 128 52 52 63 63 74 74 85 95 106 106 117 117) ("[" 15 17 135 137 25 125) ("\\" 122 122 113 113 104 104 95 95 86 86 77 77 68 68 59 59) ("]" 14 16 134 136 26 126) ("^" 102 102 113 113 124 124 135 135 126 126 117 117 108 108) ("_" 21 29) ("`" 125 125 134 134) ("a" 43 46 48 48 52 72 57 97 83 86 103 106) ("b" 42 43 45 46 54 54 57 58 68 98 97 97 105 106 94 94 132 132 53 133) ("c" 44 46 53 53 57 58 52 92 93 93 104 106 97 98 108 108) ("d" 44 45 47 48 52 92 53 53 56 56 93 93 104 105 96 96 136 136 57 137) ("e" 44 46 53 53 57 58 52 92 93 93 104 106 97 98 88 88 73 78) ("f" 43 46 54 124 93 93 95 96 135 137 128 128) ("g" 13 16 22 32 27 97 107 108 66 66 96 96 54 55 104 105 63 63 93 93 62 92) ("h" 42 44 46 48 57 97 53 133 132 132 94 94 105 106) ("i" 43 47 55 105 103 104 135 135) ("j" 22 22 13 15 26 106 104 105 136 136) ("k" 42 44 46 48 53 133 132 132 57 57 66 66 74 75 85 85 96 106 107 108) ("l" 43 47 55 135 133 134) ("m" 41 43 45 46 48 49 52 102 55 105 58 108 101 101 93 93 104 104 96 96 107 107) ("n" 42 44 46 48 53 103 57 97 102 102 94 94 105 106) ("o" 44 46 104 106 53 53 57 57 93 93 97 97 52 92 58 98) ("p" 12 15 23 103 102 102 54 54 94 94 45 46 105 106 57 58 97 98 68 88) ("q" 15 18 27 107 108 108 56 56 96 96 44 45 104 105 52 53 92 93 62 82) ("r" 42 46 54 104 102 103 95 95 106 108 99 99) ("s" 52 52 43 47 58 68 73 77 82 92 103 107 98 98) ("t" 45 47 58 58 54 124 102 103 105 107) ("u" 102 102 106 106 53 103 56 56 44 45 47 107 48 48) ("v" 45 45 54 64 56 66 73 83 77 87 92 92 98 98 101 103 107 109) ("w" 43 53 47 57 62 92 64 84 66 86 68 98 101 103 95 105 107 109) ("x" 42 44 46 48 102 104 106 108 53 53 57 57 93 93 97 97 64 64 66 66 84 84 86 86 75 75) ("y" 12 13 24 24 35 45 54 64 56 66 73 83 77 87 92 92 98 98 101 103 107 109) ("z" 92 92 58 58 102 108 42 48 97 97 86 86 75 75 64 64 53 53) ("{" 16 17 25 65 73 74 85 125 136 137) ("|" 15 135) ("}" 14 15 26 66 77 78 86 126 134 135) ("~" 112 122 133 134 125 125 116 117 128 138) ) ) (eval (list 'defun 'LM:GrText '( str col / c i l v y ) (list 'setq 'v (list 'quote (mapcar (function (lambda ( b ) (cons (car B) (mapcar '(lambda ( a ) (if a (list (rem a 10) (/ a 10)))) (cdr B))) ) ) v ) ) ) '(setq i 0 y 0) '(repeat (strlen str) (cond ( (eq (setq c (substr str 1 1)) " ") (setq i (+ i 9) str (substr str 2)) ) ( (eq c "\t") (setq i (+ i 36) str (substr str 2)) ) ( (eq c "\n") (setq i 0 y (- y 16) str (substr str 2)) ) ( (setq l (cons (mapcar (function (lambda ( a ) (if a (list (+ (car a) i) (+ (cadr a) y))) ) ) (cdr (assoc c v)) ) l ) str (substr str 2) i (+ i 9) ) ) ) ) '(cons col (apply 'append l)) ) ) (LM:GrText str col) ) Quote
Lee Mac Posted September 24, 2011 Posted September 24, 2011 I see - In that case you may need to use a getreal prompt, however you then cannot use the base point to visually pick the angle. So perhaps the compromise may be to use a separate getkword prompt for Clockwise/Anticlockwise. Nice use of GrText Quote
ketxu Posted September 24, 2011 Author Posted September 24, 2011 Oh, i see. Now i change the method to input Angle ^^ GrText is nice by itself ^^ Thanks you for this function.. Ah, once more thing, How could i insert other symbol to it list by myself? ^^ Quote
pBe Posted September 24, 2011 Posted September 24, 2011 Both angles are identical. You are right Lee! Quote
Lee Mac Posted September 24, 2011 Posted September 24, 2011 Ah, once more thing, How could i insert other symbol to it list by myself? ^^ It's not straightforward unfortunately Quote
ketxu Posted September 24, 2011 Author Posted September 24, 2011 It's not straightforward unfortunately I think so also. i just want the way you did it.. I have do a grtext by myself a year ago (for Vietnamese language), but it very very long code, and my way is draw pline with every char, and get coordinates, and make grvecs with it... After see your code, i forget my codes completely Quote
