rajuks Posted October 14, 2008 Posted October 14, 2008 I have created a new tool pallete and i want to use one tool to run vba macro developed by me. vbarun test1 where test1 is the macro name which needs to be run when i click on one of my tool. Thanks satya Quote
GhostRider Posted October 14, 2008 Posted October 14, 2008 I'm no expert but I have some that use this to call Vba command: ^C^C(command "vbastmt" "test1") Quote
ZenCad1960 Posted October 14, 2008 Posted October 14, 2008 I have created a new tool pallete and i want to use one tool to run vba macro developed by me. vbarun test1 where test1 is the macro name which needs to be run when i click on one of my tool. Thanks satya Satya, I do the same thing and I use this format for running the code. (Your code name was placed in the example): This next line goes in the "Command String" Line ^C^C-vbarun;Project.dvb!Module1.Test1 Hope this helps! Zen Quote
rajuks Posted October 15, 2008 Author Posted October 15, 2008 Thank you very much for your reply and suggestions. i have adopted your suggestions and it is successfully running. thanks once again. satya Quote
