j_spawn_h Posted September 26, 2011 Posted September 26, 2011 I have this lisp routine that rounds and puts the length on the line, but I would like for it to always come out with an even number. Is that possible? (defun c:rl () (prompt "enter roof slope rise for rafter") (setq raf1 (getstring "\n INPUT: 2,3,4,5,6,7,8,9,10,12,14,15,16")) (if (= raf1 "2") (setq raf2 1.014)) (if (= raf1 "3") (setq raf2 1.031)) (if (= raf1 "4") (setq raf2 1.054)) (if (= raf1 "5") (setq raf2 1.083)) (if (= raf1 "6") (setq raf2 1.118)) (if (= raf1 "7") (setq raf2 1.158)) (if (= raf1 "8") (setq raf2 1.202)) (if (= raf1 "9") (setq raf2 1.250)) (if (= raf1 "10") (setq raf2 1.302)) (if (= raf1 "11") (setq raf2 1.357)) (if (= raf1 "12") (setq raf2 1.414)) (if (= raf1 "13") (setq raf2 1.475)) (if (= raf1 "14") (setq raf2 1.537)) (and (setq ss (ssget "_:L" '((0 . "LINE")))) (while (setq en (ssname ss 0)) (setq ed (entget en)) (setq p10 (cdr (assoc 10 ed))) (setq p11 (cdr (assoc 11 ed))) (setq mpt (mapcar '(lambda (a b) (* (+ a b) 0.5)) p10 p11)) (setq d2d (distance (cdr (reverse p10)) (cdr (reverse p11)))) (setq d1d (/ d2d 12.)) (setq d3d (* d1d raf2)) (if (<= d3d 8.0) (setq d4d (fix (+ d3d 1)))) (if (>= d3d 9.0) (setq d4d (fix (* (+ (/ d3d 2.0) 0.5)2.0)))) (setq lan (angle p10 p11)) (setq dir (if (< (* pi 0.5) lan (* pi 1.5)) - +)) (setq tan (if (> (* pi 1.5) lan (* pi 0.5)) (+ lan pi) lan)) (entmake (list (cons 0 "TEXT") (cons 8 (getvar "CLAYER")) (cons 7 (getvar "TEXTSTYLE")) (cons 40 (getvar "TEXTSIZE")) (cons 72 4) (setq fg(cons 10 (polar mpt (dir (angle p10 p11) (* pi 0.5)) (getvar "TEXTSIZE")))) (setq hg(cons 11 (polar mpt (dir (angle p10 p11) (* pi 0.5)) (getvar "TEXTSIZE")))) (cons 50 tan) (setq rb1 (cons 1 (strcat (itoa d4d) "'"))))) (ssdel en ss))) (prin1)) Quote
Lt Dan's legs Posted September 26, 2011 Posted September 26, 2011 (setq dist (getdist "\nSpecify distance: ")) (setq disttostring (rtos dist 2 0)) Quote
marko_ribar Posted September 26, 2011 Posted September 26, 2011 if odd d4d => d4d = first higher number by 1 (defun c:rl () (prompt "enter roof slope rise for rafter") (setq raf1 (getstring "\n INPUT: 2,3,4,5,6,7,8,9,10,12,14,15,16")) (if (= raf1 "2") (setq raf2 1.014)) (if (= raf1 "3") (setq raf2 1.031)) (if (= raf1 "4") (setq raf2 1.054)) (if (= raf1 "5") (setq raf2 1.083)) (if (= raf1 "6") (setq raf2 1.118)) (if (= raf1 "7") (setq raf2 1.158)) (if (= raf1 "8") (setq raf2 1.202)) (if (= raf1 "9") (setq raf2 1.250)) (if (= raf1 "10") (setq raf2 1.302)) (if (= raf1 "11") (setq raf2 1.357)) (if (= raf1 "12") (setq raf2 1.414)) (if (= raf1 "13") (setq raf2 1.475)) (if (= raf1 "14") (setq raf2 1.537)) (and (setq ss (ssget "_:L" '((0 . "LINE")))) (while (setq en (ssname ss 0)) (setq ed (entget en)) (setq p10 (cdr (assoc 10 ed))) (setq p11 (cdr (assoc 11 ed))) (setq mpt (mapcar '(lambda (a b) (* (+ a b) 0.5)) p10 p11)) (setq d2d (distance (cdr (reverse p10)) (cdr (reverse p11)))) (setq d1d (/ d2d 12.)) (setq d3d (* d1d raf2)) (if (<= d3d 8.0) (setq d4d (fix (+ d3d 1)))) (if (>= d3d 9.0) (setq d4d (fix (* (+ (/ d3d 2.0) 0.5)2.0)))) [highlight](if (/= (/ (float d4d) 2) (fix (/ (float d4d) 2))) (setq d4d (+ d4d 1)) )[/highlight] (setq lan (angle p10 p11)) (setq dir (if (< (* pi 0.5) lan (* pi 1.5)) - +)) (setq tan (if (> (* pi 1.5) lan (* pi 0.5)) (+ lan pi) lan)) (entmake (list (cons 0 "TEXT") (cons 8 (getvar "CLAYER")) (cons 7 (getvar "TEXTSTYLE")) (cons 40 (getvar "TEXTSIZE")) (cons 72 4) (setq fg(cons 10 (polar mpt (dir (angle p10 p11) (* pi 0.5)) (getvar "TEXTSIZE")))) (setq hg(cons 11 (polar mpt (dir (angle p10 p11) (* pi 0.5)) (getvar "TEXTSIZE")))) (cons 50 tan) (setq rb1 (cons 1 (strcat (itoa d4d) "'"))))) (ssdel en ss))) (prin1)) M.R. Quote
David Bethel Posted September 26, 2011 Posted September 26, 2011 A test for even integers that rounds up: (defun even (n) (if (zerop (rem n 2)) n (1+ n))) I don't quite understand the program, but the front end could be compacted: [b][color=BLACK]([/color][/b]initget 7[b][color=BLACK])[/color][/b] [b][color=BLACK]([/color][/b]setq rise [b][color=FUCHSIA]([/color][/b]getint [color=#2f4f4f]"\nSlope Rise in 12: "[/color][b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b] [b][color=BLACK]([/color][/b]setq mp [b][color=FUCHSIA]([/color][/b]/ 1. [b][color=NAVY]([/color][/b]sin [b][color=MAROON]([/color][/b]angle '[b][color=GREEN]([/color][/b]0 0[b][color=GREEN])[/color][/b] [b][color=GREEN]([/color][/b]list rise 12[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b] -David Quote
j_spawn_h Posted September 26, 2011 Author Posted September 26, 2011 Thank you to all of you. David yours worked perfect. I knew I could do the top smaller but I got lazy and didn't want to look up the math on it. Thank you again Quote
BlackBox Posted September 26, 2011 Posted September 26, 2011 (edited) (defun c:rl () (prompt "enter roof slope rise for rafter") (setq raf1 (getstring "\n INPUT: 2,3,4,5,6,7,8,9,10,12,14,15,16")) (if (= raf1 "2") (setq raf2 1.014)) (if (= raf1 "3") (setq raf2 1.031)) (if (= raf1 "4") (setq raf2 1.054)) (if (= raf1 "5") (setq raf2 1.083)) (if (= raf1 "6") (setq raf2 1.118)) (if (= raf1 "7") (setq raf2 1.158)) (if (= raf1 "8") (setq raf2 1.202)) (if (= raf1 "9") (setq raf2 1.250)) (if (= raf1 "10") (setq raf2 1.302)) (if (= raf1 "11") (setq raf2 1.357)) (if (= raf1 "12") (setq raf2 1.414)) (if (= raf1 "13") (setq raf2 1.475)) (if (= raf1 "14") (setq raf2 1.537)) (and (setq ss (ssget "_:L" '((0 . "LINE")))) (while (setq en (ssname ss 0)) (setq ed (entget en)) (setq p10 (cdr (assoc 10 ed))) (setq p11 (cdr (assoc 11 ed))) (setq mpt (mapcar '(lambda (a b) (* (+ a b) 0.5)) p10 p11)) (setq d2d (distance (cdr (reverse p10)) (cdr (reverse p11)))) (setq d1d (/ d2d 12.)) (setq d3d (* d1d raf2)) (if (<= d3d 8.0) (setq d4d (fix (+ d3d 1)))) (if (>= d3d 9.0) (setq d4d (fix (* (+ (/ d3d 2.0) 0.5)2.0)))) [highlight](if (/= (/ (float d4d) 2) (fix (/ (float d4d) 2))) (setq d4d (+ d4d 1)) )[/highlight] (setq lan (angle p10 p11)) (setq dir (if (< (* pi 0.5) lan (* pi 1.5)) - +)) (setq tan (if (> (* pi 1.5) lan (* pi 0.5)) (+ lan pi) lan)) (entmake (list (cons 0 "TEXT") (cons 8 (getvar "CLAYER")) (cons 7 (getvar "TEXTSTYLE")) (cons 40 (getvar "TEXTSIZE")) (cons 72 4) (setq fg(cons 10 (polar mpt (dir (angle p10 p11) (* pi 0.5)) (getvar "TEXTSIZE")))) (setq hg(cons 11 (polar mpt (dir (angle p10 p11) (* pi 0.5)) (getvar "TEXTSIZE")))) (cons 50 tan) (setq rb1 (cons 1 (strcat (itoa d4d) "'"))))) (ssdel en ss))) (prin1)) Marko j_spawn_h, among other things, consider using COND in lieu of repeated IF statements. Also, consider testing for valid user input, before continuing with routine: Pseudo code: (defun c:RL ( / [color=seagreen];| Don't forget to localize vars |;[/color]) (if (and (princ "enter roof slope rise for rafter") (setq raf1 (getstring "\n INPUT: 2,3,4,5,6,7,8,9,10,12,14,15,16")) (cond [color=seagreen];| Options here |;[/color])) (progn [color=seagreen];; <-- Do soemthing[/color] ) (prompt "\n** Invalid input ** ")) (princ)) HTH Edited September 26, 2011 by BlackBox Code author corrected Quote
