colmguckian Posted September 27, 2011 Posted September 27, 2011 I have a vbdotnet code to create a command which scales the drawing Please see attached a print screen of the code You will see that I am getting two errors. How do I fix these errors. How do I tweek the code so that it scales all objects in the drawing by 25.4. cscaleall.doc Quote
Jeff H Posted September 27, 2011 Posted September 27, 2011 (edited) I am not familiar with VBA for AutoCAD but that is what it looks like, but From AutoCAD .NET Developer's Guide in help You move, scale, rotate and mirror an object using a 4 by 4 transformation matrix represented by a Matrix3d object and the TransformBy method LINK This LINK shows an example. Here is scaling all objects in model space 25.4 using the origin as the base point <CommandMethod("ScaletoMetric")> _ Public Sub ScaletoMetric() Dim doc As Document = Application.DocumentManager.MdiActiveDocument Dim ed As Editor = doc.Editor Dim db As Database = doc.Database Using trx As Transaction = db.TransactionManager.StartTransaction() Dim bt As BlockTable = trx.GetObject(db.BlockTableId, OpenMode.ForRead) Dim modelBtr As BlockTableRecord = trx.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForRead) For Each objId As ObjectId In modelBtr Dim ent As Entity = trx.GetObject(objId, OpenMode.ForWrite) ent.TransformBy(Matrix3d.Scaling(25.4, Point3d.Origin)) Next trx.Commit() End Using End Sub Edited September 27, 2011 by Jeff H Quote
colmguckian Posted September 28, 2011 Author Posted September 28, 2011 Thats perfect Jeff. Thanks for the code and the links Quote
