Be_cool Posted September 28, 2011 Posted September 28, 2011 Is it possible, and how can i import parameters from excel in to idw. For example, i have to do prototype with name PT-1060 and after 10 days i have to change name of product on all 40 idws!! Regards Alexandar Quote
Bishop Posted September 28, 2011 Posted September 28, 2011 Set the information in the iProperties for your parts or assemblies. If you have your drawing templates set up correctly, the information should populate through from the parts and assemblies to the drawing. After your ten days are up, change the information in the model files, and then next time you open the drawing, it should have changed over automatically already. Quote
Be_cool Posted September 29, 2011 Author Posted September 29, 2011 That's what I'm doing...but that's the annoying part of my work, because i have to enter in iProperties of every part. I want to find solution how to change name and stock number on all idw-s by changing name an stock number in excel. Quote
MarkFlayler Posted September 29, 2011 Posted September 29, 2011 You can use Design Assistant to Copy your iProperties over a entire drawing set. Quote
Be_cool Posted September 30, 2011 Author Posted September 30, 2011 WoooooooW!!!! Ty Mark!! U saved my nerves... Quote
