With this simple routine I want to select entities from a range of options.
Why not work with polylines? I appreciate the help to be able to also select polylines and hatch.
I know it will be simple, but for a beginner ...
;select entities to delet
(defun c:DELENT (/ gets sel)
(initget 1 "T L C A P")
(setq gets (getkword "\nSelect option: (T)ext; (L)line; (C)ircle; (A)rc; (P)olyline: "))
(cond
((= gets "T")
(setq sel (ssget "x" '((0 . "TEXT" ))))
(command "erase" sel)
((= gets "L")
(setq sel (ssget "x" '((0 . "LINE" ))))
((= gets "C")
(setq sel (ssget "x" '((0 . "CIRCLE" ))))
((= gets "A")
(setq sel (ssget "x" '((0 . "ARC" ))))
((= gets "P")
(setq sel (ssget "x" '((0 . "POLYLINE" ))))
) ;end_cond
Maybe this..?
(setq sel (ssget "x" '((0 . "*POLYLINE" ))))
that's it. I also decided for the hatch.
Tanks
Hope you don't mind
(defun c:entdel ( / *error* gets ss id)
 (defun *error* ( msg )
        (princ (strcat "\n** Error: " msg " **"))
 (initget 1 "Text Line Circle Arc Polyline")
 (if
   (and
     (setq gets (getkword "\nSelect option [Text/Line/Circle/Arc/Polyline]: "))
     (setq ss
       (ssget "_x"
         (list
           (cons 0
             (if (eq "Polyline" gets)
               (strcat "*" gets) gets
   (repeat (setq id (sslength SS))
     (entdel (ssname ss (setq id (1- id))))
   ) (prompt (strcat "\nNo " gets " found!"))
 )(princ)
Much better and more orderly.
By the way, also wanted to include the option to entities hatch and bloks.
Thank you.
Lee Mac,
Yes, of course. I think this way is more direct. In addition, there's a learning component.
Ok, just making sure you were aware of the QSelect command ;)
and SSX and Filter.
