bjenk8100 Posted September 29, 2011 Posted September 29, 2011 I cant figure out an efficient way to hallow something out after it is a 3d solid. Usually if I want this I will draw it in 2d knowing I will extrude one region and not the other. My problem comes with a sphere. I need to put a square hole through it. Its probably an easy 123 operation but am unfamiliar. Any help would be greatly appreciated. Quote
ReMark Posted September 29, 2011 Posted September 29, 2011 HOLLOW out? Couldn't you just extrude a square and subtract it from your sphere? Or you could draw a square and use the PushPull command to punch through the sphere. Quote
bjenk8100 Posted September 30, 2011 Author Posted September 30, 2011 wow, i never used subtract before. thanks. Quote
ReMark Posted September 30, 2011 Posted September 30, 2011 wow, i never used subtract before. thanks. Really? You must be a very good designer then to be able to avoid using Subtract. Have you used Slice at all? Quote
rkent Posted September 30, 2011 Posted September 30, 2011 SHELL is a good command for what you are after. Quote
