Is there a way to change the limit of 180 degrees when dimensioning (or drawing) an angle? The reason I ask is I am trying to find a way to show obtuse angles for a navigational question. i'd like to be able to specify an angle from 1 to 359 degrees.
Thanks for any ideas.
Thank you, very much appreciated.
I guess there is no way to change how you enter angles when drawing lines from a common point? The angle will always stop at 180 and start from the opposite rotation?
