VVA Posted September 30, 2011 Posted September 30, 2011 The program allows you to apply color schemes in AutoCAD (like WinAmp) Settings are stored in xml file. Dwgru_color_schema.xml file should be located in ways to support AutoCAD. Defined by 2 commands: ACS - applies the selected scheme GetShema - printed in the text box fragment settings xml file for the current color scheme. color sheme.ZIP Quote
Lee Mac Posted September 30, 2011 Posted September 30, 2011 Very original Vladimir, I like the idea Quote
ketxu Posted September 30, 2011 Posted September 30, 2011 Thanks VVA. It's new idea to relax eyes and some ex how to do with XML file ^^ Quote
VVA Posted September 30, 2011 Author Posted September 30, 2011 Thank you for your interest. This code was written as a demonstration of the formation of a dialogue on the fly and store data in xml file. Quote
ketxu Posted October 1, 2011 Posted October 1, 2011 Hi VVA, it's funny to learn news ^^ I'm not good in XML structure, so i modified it to Registry store to make a new dirty verision, hope you don't mind. And i want to ask how to use $Reason 4 to apply like pick Apply button when double click in one listbox' item. Some of example in InternEt not enough for my very low IQ score ^^ ;;-------------------=={ Color sheme }==------------------------;; ;; ;; ;; Change the color scheme in AutoCAD (like WinAmp) ;; ;; the data of color schemes for AutoCAD stored in xml file ;; ;;--------------------------------------------------------------;; ;; Author: Vladimir Azarko (VVA), Copyright © 2011 - www.dwg.ru ;; ;; Some of updates : Ketxu (Nguyen Son Tung ;; ;;--------------------------------------------------------------;; ;; Special thanks ;; ;; gomer - idea ;; ;; Vov.ka - xml parser ;; ;; Alexandr Rivilis - GetOleColor, GerRGB ;; ;;--------------------------------------------------------------;; ;; ALL RIGHTS REMOVED ;; ;;--------------------------------------------------------------;; ;;--------------------------------------------------------------;; (defun c:ACS() (setq appRegPath "HKEY_CURRENT_USER\\Software\\ACS\\") (defun ACS:WK (key)(vl-registry-write (setq rt (strcat appRegPath key))) rt) (defun ACS:WV (path key val)(vl-registry-write (ACS:WK path) key (vl-princ-to-string val))) ;Reg write (defun ACS:W_Shema (x) (ACS:WV (car x) nil (cadr x))) (defun ACS:RV (path key)(read(vl-registry-read (strcat appRegPath path) key))) ;Reg read (defun ACS:Apply_Shema (themes)(mapcar '(lambda(x y) (set_shema (eval x) y)) lstFunc_Put (ACS:RV themes nil))) (defun ACS:Insert_Shema (sName lstColor) ;Insert Shema to Reg (or sName (setq sName (strcat "Themes - " (menucmd (strcat "m=$(edtime," (rtos (getvar "DATE") 2 ",DD:MO:YY - HH:MM:SS)"))))) (ACS:W_Shema (cons sName (list (cond (lstColor) (list ((lambda (display) (mapcar '(lambda (x) (GetRGB (vlax-variant-value (vlax-variant-change-type (eval (list x display)) vlax-vblong ) ;_ end of vlax-variant-change-type ) ;_ end of vlax-variant-value ) ;_ end of GetRGB ) ;_ end of lambda (list 'vla-get-graphicswinmodelbackgrndcolor 'vla-get-modelcrosshaircolor 'vla-get-textwinbackgrndcolor 'vla-get-textwintextcolor 'vla-get-graphicswinlayoutbackgrndcolor 'vla-get-layoutcrosshaircolor) ;_ end of list ) ;_ end of mapcar ) ;_ end of lambda (vla-get-display (vla-get-preferences (vlax-get-acad-object)) ) ;_ end of vla-get-display ) ) ) ) ) ) ) ;;; A. Rivilis (defun GetOleColor (r g b) (+ r (lsh g (lsh b 16))) (defun GetRGB (Olecolor) (list (logand Olecolor 255) ;; R (logand (lsh Olecolor - 255) ;; G (logand (lsh Olecolor -16) 255) ;; B ) ;_ end of list ) ;_ end of defun (defun set_shema (func lst) ;;; func - function like 'vla-put-ModelCrosshairColor ;;; lst - RGB list (R G B) or (255 0 234) (func (vla-get-display (vla-get-preferences (vlax-get-acad-object)) ) ;_ end of vla-get-display (vlax-make-variant (apply 'GetOleColor lst) vlax-vblong) ) ;_ end of func ) ;_ end of defun ;VVA : i change sth to learn about action in DCL (defun mydcl (zagl info-list / fl ret dcl_id) (vl-load-com) (or zagl (setq zagl "Select")) (setq fl (vl-filename-mktemp "mip" nil ".dcl")) (setq ret (open fl "w") ud (lambda() (start_list "info" 3) (mapcar 'add_list (setq info-list (acad_strlsort (vl-registry-descendents appRegPath)))) (end_list)) ) (mapcar '(lambda (x) (write-line x ret)) (list "mip_msg : dialog { " (strcat "label=\"" zagl "\";") " :list_box {" "alignment=top ;width=51 ;allow_accept = true;" "tabs = \"16 32\";tab_truncate = true;" (if (> (length info-list) 26) "height= 26 ;" (strcat "height= " (itoa (+ 3 (length info-list))) ";") ) ;_ end of if "is_tab_stop = false ;" "key = \"info\";}" " :row {" " :button {" "label=\" OK \";" "key = \"Accept\";" "is_cancel = true;}" " :button {" "label=\"Apply\";" "key = \"kApply\";}" " :button {" "label=\"Insert\";" "key = \"kInsert\";}" " :button {" "label=\"Delete\";" "key = \"kDelete\";}" " :button {" "label=\"Cancel \";" "key = \"kCancel\";}" "}}" ) ;_ end of list ) ;_ end of mapcar (setq ret (close ret)) (if (and (not (minusp (setq dcl_id (load_dialog fl)))) (new_dialog "mip_msg" dcl_id) ) ;_ end of and (progn (start_list "info") (mapcar 'add_list info-list) (end_list) (set_tile "info" "0") (setq ret (car info-list)) (action_tile "info" "(setq ret (nth (atoi $value) info-list))" ) ;_ end of action_tile (action_tile "kCancel" "(progn(setq ret nil)(done_dialog 0))" ) ;_ end of action_tile (action_tile "Accept" "(done_dialog 1)") (action_tile "kApply" "(ACS:Apply_Shema (nth (atoi(get_tile \"info\")) info-list))") (action_tile "kInsert" "(ACS:Insert_Shema nil nil)(ud)") (action_tile "kDelete" "(vl-registry-delete (strcat appRegPath (nth (atoi(get_tile \"info\")) info-list)))(ud)") (start_dialog) ) ;_ end of progn ) ;_ end of if (unload_dialog dcl_id) (vl-file-delete fl) ret) (setq lstFunc_Put '( vla-put-GraphicsWinModelBackgrndColor vla-put-ModelCrosshairColor vla-put-TextWinBackgrndColor vla-put-TextWinTextColor vla-put-GraphicsWinLayoutBackgrndColor vla-put-LayoutCrosshairColor )) (cond ((not (vl-registry-descendents appRegPath)) ;First run (mapcar 'ACS:W_Shema (list (cons "Classic" (list (list '(0 0 0) '(255 255 255) '(255 255 255) '(0 0 0) '(255 255 255) '(0 0 0)))) (cons "Negative" (list (list '(255 255 255) '(0 0 0) '(0 0 0) '(255 255 255) '(255 255 255) '(0 0 0)))) (cons "Winter" (list (list '(214 214 214) '(0 0 0) '(255 255 255) '(0 0 0) '(255 255 255) '(0 0 0)))) (cons "The Matrix" (list (list '(0 0 0) '(0 255 0) '(0 0 0) '(0 255 0) '(255 255 255) '(0 0 0)))) (cons "Ocean" (list (list '(0 0 0) '(255 255 255) '(0 173 173) '(255 255 255) '(255 255 255) '(0 0 0)))) (cons "Pascal" (list (list '(0 0 0) '(255 255 255) '(0 0 255) '(255 255 0) '(255 255 255) '(0 0 0)))) (cons "Sakura" (list (list '(0 0 0) '(246 223 233) '(246 223 233) '(120 70 44) '(255 255 255) '(0 0 0)))) (cons "Deep dive" (list (list '(38 40 48) '(127 159 255) '(38 40 48) '(127 159 255) '(51 102 255) '(0 0 0)))) ) ) ) ) (if (setq item (mydcl "Select Shema to Apply :" (acad_strlsort (vl-registry-descendents appRegPath)))) (ACS:Apply_Shema item) ) ) Quote
VVA Posted October 1, 2011 Author Posted October 1, 2011 And i want to ask how to use $Reason 4 to apply like pick Apply button when double click in one listbox' item. " :list_box {" "alignment=top ;width=51 ;allow_accept = true;" "tabs = \"16 32\";tab_truncate = true;" (if (> (length info-list) 26) just read these threads Double Click in a List_Box Dialog Boxes in Action AutoLISP treasure chest Using double-click in a dcl list box Quote
ketxu Posted October 1, 2011 Posted October 1, 2011 Thanks you VVA, it's useful, i've known what to do ^^ Quote
