vb.net how to close a polyline?
Hi,
I want calculate the area of a closed polyline. I pick up a polyline and If it is not closed, I want to close it. But the code below doesn't work.
                            If lwpoly.Closed = False Then
                               lwpoly.Closed = True
                           End If
It returns an internal error saying "eNotOpenForWrite". Just wondering how should I close a polyline with vb.net 2008 express for autocad 2010.
Thanks in advance
Cean
Looks like you opened it for read so try
               lwpoly.UpgradeOpen()
           End If
Thanks Jeff, It works.
I was playing with a code from theswamp - .net polyline routines
It has one line like this:
Dim obj As DBObject = tr.GetObject(res.ObjectId, OpenMode.ForRead)
I think I should change here.
