I am running Autocad 2011 and I get a load error, I used to use this lisp in Autocad 2005 and worked great still like ti better then the new auto number in express tols
;DDNUMB.LSP for release 15
;Auto numbers text strings.
;Written by: S. Restmeyer 3/01
;;;----------------------ERROR FUNCTION----------------------------
(DEFUN ERR (S)				;if an error (such as CTRL-C)
				;occurs while this command is active...
 (if (not (member s '("console break" "Function cancelled")))
   (princ (strcat "\nError: " s))
 (command "_.UNDO" "_E")		;end any outstanding UNDO group
 (setvar "cmdecho" cmd)		;restore saved mode
 (setq *error* olderr)
;;;---------------------- MAIN PROGRAM ----------------------------
(defun C:DDNUMB (/ CMD dcl_id1 olderr)
 (setq	olderr	*error*
*error*	err
 (SETQ CMD (GETVAR "CMDECHO"))
 (command "_.UNDO" "_G")
 (setvar "cmdecho" 0)
 (defun set_replace ()
   (cond
     ((= (get_tile "do_replace") "0")
      (set_tile "sort_type" "0")
      (mode_tile "sort_type" 1)
      (set_tile "start_no" " ")
      (mode_tile "start_no" 1)
      (set_tile "txt_inc" " ")
      (mode_tile "txt_inc" 1)
   (cond
     ((= (get_tile "do_replace") "1")
      (mode_tile "sort_type" 0)
      (mode_tile "start_no" 0)
      (mode_tile "txt_inc" 0)
      (if sort_type
   (set_tile "sort_type" sort_type)
      (if txt_inc
   (set_tile "txt_inc" (rtos txt_inc 2 0))
   (set_tile "txt_inc" "1")
      (if start_no
   (set_tile "start_no" (rtos start_no 2 0))
   (set_tile "start_no" "1")
 (defun my_help ()
   (setq file_name (findfile "autonumb.pdf"))
   (startapp "acrobat.exe" (strcat "\"" file_name "\""))
      (defun get_data ()
 (setq suffix (get_tile "suffix"))
 (setq prefix (get_tile "prefix"))
 (setq start_no (atoi (get_tile "start_no")))
 (setq txt_inc (atoi (get_tile "txt_inc")))
 (setq sort_type (get_tile "sort_type"))
 (setq do_replace (get_tile "do_replace"))
;;;-----------THIS SECTION RETRIEVES USER INPUT INFORMATION------------
    (setq dcl_id1 (load_dialog "autonumb.dcl"))
     (if (not (new_dialog "ddstart" dcl_id1))
(exit)
 (setq sort_list '("Selection" "Top-Bottom" "Left-Right" "Bottom-Top" "Right-Left"))
	(start_list "sort_type")
(mapcar 'add_list sort_list)
	(end_list)
 (if sort_type
 (if prefix
   (set_tile "prefix" prefix)
 (if suffix
   (set_tile "suffix" suffix)
 (if start_no
 (if txt_inc
   (action_tile "do_replace" "(set_replace)")
   (action_tile "numb_hlp" "(my_help)")
   (action_tile "accept" "(setq start_ok T)(get_data)(done_dialog 1)")
   (action_tile "cancel" "(setq start_ok nil)(done_dialog 0)")
   (start_dialog)
     (unload_dialog dcl_id1)
;;;---------------THIS SECTION MODIFIES SELECTED TEXT-----------------
 (defun get_txt (/ sset sset1 sset2 sset3 test num llen temp old)
   (setq sset (ssget '((0 . "TEXT"))))
   (setq num 0)
  (if (= do_replace "1")
   (cond
     ((= sort_type "0")
    (while (< num (sslength sset))
      (setq temp (entget (ssname sset num)))
      (setq old (assoc 1 temp))
  (setq new (cons 1 (strcat prefix (rtos start_no 2 0) suffix)))
           (setq temp (subst new old temp))
           (entmod temp)
      (setq start_no (+ start_no txt_inc))
      (setq num (+ num 1))
     ((= sort_type "1")
      (setq temp (caddr (assoc 10 (entget (ssname sset num)))))
      (setq sset1 (list temp))
      (setq sset1 (append sset1 (list temp)))
      (setq sset2 (list ""))
      (while (< (- (length sset2) 1) (sslength sset))
    (setq temp (apply 'max sset1))
    (setq sset2 (append sset2 (list temp)))
    (setq sset3 (list ""))
    (setq num (- (length sset1) 1))
     (while (> num -1)
(setq test (nth num sset1))
(if (not (member test sset2))
  (setq sset3 (append sset3 (list test)))
(setq num (- num 1))
      (setq sset1 (cdr sset3))
      (setq sset2 (cdr sset2))
      (setq llen 0)
      (while (< llen (length sset2))
 (setq test (nth llen sset2))
 (setq num 0)
 (while (not (= (caddr (assoc 10 (entget (ssname sset num)))) test))
           (entmod temp)
      (setq llen (+ llen 1))
     ((= sort_type "2")
      (setq temp (cadr (assoc 10 (entget (ssname sset num)))))
     (while (> num -1)
     (setq llen (- (length sset2) 1))
      (while (> llen -1)
 (setq num 0)
 (while (not (= (cadr (assoc 10 (entget (ssname sset num)))) test))
           (entmod temp)
      (setq llen (- llen 1))
     ((= sort_type "3")
     (while (> num -1)
      (while (> llen -1)
 (setq num 0)
           (entmod temp)
     ((= sort_type "4")
     (while (> num -1)
      (setq llen 0)
 (setq num 0)
           (entmod temp)
      (setq start_no nil)
      (setq txt_inc nil)
  (setq new (cons 1 (strcat  prefix (cdr old) suffix)))
           (entmod temp)
  (if start_ok
   (get_txt)
Edited by Efeezy
*error*	err
   (cond
   (cond
      (if sort_type
      (if txt_inc
      (if start_no
 (defun my_help ()
      (defun get_data ()
(exit)
	(end_list)
 (if sort_type
 (if prefix
 (if suffix
 (if start_no
 (if txt_inc
   (start_dialog)
   (setq num 0)
   (cond
     ((= sort_type "0")
           (entmod temp)
     ((= sort_type "1")
     (while (> num -1)
      (setq llen 0)
 (setq num 0)
           (entmod temp)
     ((= sort_type "2")
     (while (> num -1)
      (while (> llen -1)
 (setq num 0)
           (entmod temp)
     ((= sort_type "3")
     (while (> num -1)
      (while (> llen -1)
 (setq num 0)
           (entmod temp)
     ((= sort_type "4")
     (while (> num -1)
      (setq llen 0)
 (setq num 0)
           (entmod temp)
      (setq start_no nil)
      (setq txt_inc nil)
           (entmod temp)
  (if start_ok
   (get_txt)
Could you post the autonumb.dcl file? Maybe you just need to add that file to your support folder. Just a thought without looking to deep into it.
so what do I use this file for, or what do I need to do this this? It has been years since I have had to load this on a new pc....
// Corresponding dialogue for DDNUMB.LSP
//dcl_settings : default_dcl_settings { audit_level = 3; }
ddstart : dialog {
    label = "Auto Number";
initial_focus = "prefix";
	: row {
	: boxed_column {
		fixed_width = true;
		label = "&Prefix";
			: edit_box {
				key = "prefix";
				mnemonic = "P";
				fixed_width = true;
	: boxed_column {
		fixed_width = true;
		label = "Start &No";
			: edit_box {
				key = "start_no";
				mnemonic = "N";
				fixed_width = true;
	: boxed_column {
		fixed_width = true;
		label = "&Suffix";
			: edit_box {
				key = "suffix";
				mnemonic = "S";
				fixed_width = true;
: row {
	: boxed_column {
		fixed_width = true;
		label = "&Increment";
			: edit_box {
				key = "txt_inc";
				mnemonic = "I";
				fixed_width = true;
	: boxed_column {
		fixed_width = true;
		label = "Sort &By";
			: popup_list {
				key = "sort_type";
				width = 13;
				fixed_width = true;
	: toggle {
		label = "Replace";
		key = "do_replace";
		value = 1;
	spacer_1;
	: row {
ok_cancel;
		: button {
			key = "numb_hlp";
			label = "Help";
			mnemonic = "H";
I am unable to load my autonumber DDNUMB I have tried tools-load app. I used the lisp in Autocad 2005 now trying to use it in 2011. what am I doing wrong?
*error*	err
   (cond
   (cond
      (if sort_type
      (if txt_inc
      (if start_no
 (defun my_help ()
      (defun get_data ()
(exit)
	(end_list)
 (if sort_type
 (if prefix
 (if suffix
 (if start_no
 (if txt_inc
   (start_dialog)
   (setq num 0)
   (cond
     ((= sort_type "0")
           (entmod temp)
     ((= sort_type "1")
     (while (> num -1)
      (setq llen 0)
 (setq num 0)
           (entmod temp)
     ((= sort_type "2")
     (while (> num -1)
      (while (> llen -1)
 (setq num 0)
           (entmod temp)
     ((= sort_type "3")
     (while (> num -1)
      (while (> llen -1)
 (setq num 0)
           (entmod temp)
     ((= sort_type "4")
     (while (> num -1)
      (setq llen 0)
 (setq num 0)
           (entmod temp)
      (setq start_no nil)
      (setq txt_inc nil)
           (entmod temp)
  (if start_ok
   (get_txt)
addition to the lisp in the file. What do i do with this? DCL file
ddstart : dialog {
	: row {
	: boxed_column {
		fixed_width = true;
		label = "&Prefix";
			: edit_box {
				key = "prefix";
				mnemonic = "P";
				fixed_width = true;
	: boxed_column {
		fixed_width = true;
			: edit_box {
				key = "start_no";
				mnemonic = "N";
				fixed_width = true;
	: boxed_column {
		fixed_width = true;
		label = "&Suffix";
			: edit_box {
				key = "suffix";
				mnemonic = "S";
				fixed_width = true;
: row {
	: boxed_column {
		fixed_width = true;
			: edit_box {
				key = "txt_inc";
				mnemonic = "I";
				fixed_width = true;
	: boxed_column {
		fixed_width = true;
		label = "Sort &By";
			: popup_list {
				key = "sort_type";
				width = 13;
				fixed_width = true;
	: toggle {
		label = "Replace";
		key = "do_replace";
		value = 1;
	spacer_1;
	: row {
ok_cancel;
		: button {
			key = "numb_hlp";
			label = "Help";
			mnemonic = "H";
I figured it out Load the DCL file:
C:\Program Files\AutoCAD version\Support
I combined your threads. Please post the same question only once.
Efeezy,
Is it safe to assume that everything is working now? FYI: The dcl file is the dialog box needed for your DDNUMB.lsp.
