Efeezy Posted October 3, 2011 Posted October 3, 2011 I don't know how to make a custom button and tool bar for my lisps in Autocad 2011. It used to be easy in 2000-2005... Quote
BIGAL Posted October 4, 2011 Posted October 4, 2011 It still is but use partial menus and just MENULOAD one example looking for more ***MENUGROUP=ALANSTOOLBAR ***TOOLBARS **ALANSTOOLS ID_TbModify [_Toolbar("Alans", _Right, _Show, 0, 0, 1)] AECC_ShowTS [_Button("Show Toolspace", RCDATA_16_IMAGE, RCDATA_16_IMAGE)]^C^C^C^P_ShowTS ID_Matchprop [_Button("Match Properties", RCDATA_16_MATCH, RCDATA_16_MATCH)]^C^C_matchprop ID_Erase [_Button("Erase", RCDATA_16_ERASE, RCDATA_32_ERASE)]^C^C_erase ID_Copy [_Button("Copy", RCDATA_16_COPYOB, RCDATA_32_COPYOB)]$M=$(if,$(eq,$(substr,$(getvar,cmdnames),1,4),GRIP),_copy,^C^C_copy) ID_Mirror [_Button("Mirror", RCDATA_16_MIRROR, RCDATA_32_MIRROR)]$M=$(if,$(eq,$(substr,$(getvar,cmdnames),1,4),GRIP),_mirror,^C^C_mirror) ID_Offset [_Button("Offset", RCDATA_16_OFFSET, RCDATA_32_OFFSET)]^C^C_offset ID_Array [_Button("Array...", RCDATA_16_ARRREC, RCDATA_32_ARRREC)]^C^C_array ID_Move [_Button("Move", RCDATA_16_MOVE, RCDATA_32_MOVE)]$M=$(if,$(eq,$(substr,$(getvar,cmdnames),1,4),GRIP),_move,^C^C_move) ID_Rotate [_Button("Rotate", RCDATA_16_ROTATE, RCDATA_32_ROTATE)]$M=$(if,$(eq,$(substr,$(getvar,cmdnames),1,4),GRIP),_rotate,^C^C_rotate) some custom stuff Alloff [_Button("All Off","Alloff.BMP","alloff.BMP")]^c^c^c(setq surface "_COGG All Off")(load "vercheck")(load "listselect")(load "changecontours6") 50mm [_Button("50mm cont","50mm.BMP","50mm.BMP")]^c^c^c(setq surface "_COGG NS 0.05 Contours")(load "vercheck")(load "listselect")(load "changecontours6") 100mm [_Button("100mm cont","100mm.BMP","100mm.BMP")]^c^c^c(setq surface "_COGG NS 0.1 Contours")(load "vercheck")(load "listselect")(load "changecontours6") 200mm [_Button("200mm cont","200mm.BMP","200mm.BMP")]^c^c^c(setq surface "_COGG NS 0.2 Contours")(load "vercheck")(load "listselect")(load "changecontours6") 500mm [_Button("0.50m cont","500mm.BMP","500mm.BMP")]^c^c^c(setq surface "_COGG NS 0.5m Contours")(load "vercheck")(load "listselect")(load "changecontours6") 1m [_Button("1m cont","1m.BMP","1m.BMP")]^c^c^c(setq surface "_COGG NS 1m Contours" )(load "vercheck")(load "listselect")(load "changecontours6") Triangles [_Button("Triangles","TRI.BMP","TRI.BMP")]^c^c^c(setq surface "_COGG NS Triangles" )(load "vercheck")(load "listselect")(load "changecontours6") Quote
