Viu Posted October 5, 2011 Posted October 5, 2011 Hello, I'm trying to derive a part for a nested cut, however when I attempt this the other part isn't visible and doesn't show up as a solid. If I try it the other way around it says "Selected component was rejected since it causes a cyclic dependency." Thanks for your help, Viu Quote
KAOMOMAK Posted October 13, 2011 Posted October 13, 2011 I do have similar problem. It is with deriving blocks. After i derive block i can't move or rotate. Block is fixed and i can't see how to edit. I did it in Inventor 2010 without any problems, but now i just start with 2012 release. Any help would apreciate. Quote
JD Mather Posted October 13, 2011 Posted October 13, 2011 Any help would apreciate. Zip and attach files here. Quote
KAOMOMAK Posted October 13, 2011 Posted October 13, 2011 Thanks for such quick response TEST DERIVE BLOCK.ipt Quote
JD Mather Posted October 13, 2011 Posted October 13, 2011 I don't see the original file - only the derived file? Quote
KAOMOMAK Posted October 13, 2011 Posted October 13, 2011 That was just test file, i create to see how is working but i figured out how it is working. I made mistake in derive block process. I appreciate your very quick respond. Quote
